Webcast-Catalyst9k
ISDN (PRI - BRI) problem - Help required (config & debug included)
Hi everyone,
Quick description of the solution:
Remote router (BRI) should dial the main HQ router (PRI) and it should initiate a callback. At the moment we cannot even get to the callback as some of the numbers do not seem to be 'picked up' by the opposite router.
Here is a summary of the problem:
When the PRI calls the BRI when I issue "show caller xxx":
the PRI side can see the remote number but cannot see the local number
and
the BRI side can see the remote number and the local number
When the PRI is called by the BRI :
the PRI side cannot see the remote number but it can see the local number
and
the BRI side can see the remote number but not the local number.
I can email configs and debugs but an initial idea would be appreciated. Surely someone has seen this before. The PRI router is a 3640 and the BRI is a 2621.
Any ideas would be deeply appreciated,
TIA,
G.:
Dialer IOS:
HQ PRI config:
interface Dialer1
description connected to MainWAN
ip address 22.0.0.2 255.255.255.252
encapsulation ppp
no ip route-cache
no ip mroute-cache
load-interval 60
dialer pool 1
dialer remote-name MainWAN
dialer enable-timeout 2
dialer string 16201234567891
dialer caller 16201234567891 callback
dialer load-threshold 128 outbound
dialer-group 1
fair-queue
no cdp enable
ppp authentication chap
ppp multilink
interface Dialer2
description connected to MainDATA
ip address 22.0.0.6 255.255.255.252
encapsulation ppp
no ip route-cache
no ip mroute-cache
load-interval 60
dialer pool 2
dialer remote-name MainDATA
dialer string 1620123666777
dialer caller 1620123666777 callback
dialer-group 1
fair-queue
no cdp enable
ppp multilink
Remote BRI config:
interface Dialer1
description HQPRI Email
ip address 22.0.0.1 255.255.255.252
encapsulation ppp
no ip split-horizon
dialer pool 1
dialer idle-timeout 300
dialer redial interval 15 attempts 2
dialer string 01235666888
dialer caller 01235666888
dialer load-threshold 100 either
dialer-group 1
no cdp enable
ppp chap hostname MainWAN
interface Dialer2
description HQPRI Data
ip address 22.0.0.5 255.255.255.252
encapsulation ppp
no ip split-horizon
dialer pool 2
dialer string 01235666777
dialer caller 01235666777
dialer-group 2
no cdp enable
ppp chap hostname MainDATA
Debug:
HQPRI#
HQPRI#s caller ip
Line User IP Address Local Number Remote Number <->
Se1/0:1 TestWAN 22.0.0.9 777333 in
Se1/0:2 TestWAN 22.0.0.9 777333 in
Se1/0:3 TestWAN 22.0.0.9 777333 in
Se1/0:4 TestWAN 22.0.0.9 777333 in
HQPRI#
HQPRI#
HQPRI#ping 22.0.0.14
Sending 5, 100-byte ICMP Echos to 22.0.0.14, timeout is 2 seconds:
1w2d: Se1/0:15 DDR: rotor dialout [priority]
1w2d: Se1/0:15 DDR: Dialing cause ip (s=192.168.11.113, d=192.168.12.201)
1w2d: Se1/0:15 DDR: Attempting to dial 00
1w2d: ISDN Se1/0:15 Q931: TX -> SETUP pd = 8 callref = 0x7929
Bearer Capability i = 0x8890
Standard = CCITT
Transer Capability = Unrestricted Digital
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9839E
Exclusive, Channel 30
Called Party Number i = 0x81, '00'
Plan:ISDN, Type:Unknown
1w2d: ISDN Se1/0:15 Q931: RX <- SETUP_ACK pd = 8 callref = 0xF929
Progress Ind i = 0x8288 - In-band info or appropriate now available
1w2d: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on Ethernet0/0 (not full duplex), with ADRouter FastEthernet0/1 (full duplex).
1w2d: Se1/0:15 DDR: Dialing cause ip (s=22.0.0.14, d=22.0.0.14)
1w2d: Se1/0:15 DDR: Attempting to dial 1620034912345679
1w2d: ISDN Se1/0:15 Q931: TX -> SETUP pd = 8 callref = 0x792A
Standard = CCITT
Channel ID i = 0xA9839D
Exclusive, Channel 29
Called Party Number i = 0x81, '1620034912345679'
Plan:ISDN, Type:Unknown.
1w2d: ISDN Se1/0:15 Q931: RX <- SETUP_ACK pd = 8 callref = 0xF92A
Progress Ind i = 0x8288 - In-band info or appropriate now available ..
1w2d: ISDN Se1/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0xF92A.
1w2d: ISDN Se1/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0xF928
Cause i = 0x829C - Invalid number format (incomplete number)
1w2d: ISDN Se1/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x7928
1w2d: ISDN Se1/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0xF928
1w2d: Serial1/0:15: wait for isdn carrier timeout, call id=0xF929
1w2d: ISDN Se1/0:15 Q931: RX <- ALERTING pd = 8 callref = 0xF92A
1w2d: ISDN Se1/0:15 Q931: RX <- CONNECT pd = 8 callref = 0xF92A
1w2d: %LINK-3-UPDOWN: Interface Serial1/0:28, changed state to up
1w2d: Se1/0:28: interface must be fifo queue, force fifo
1w2d: %DIALER-6-BIND: Interface Se1/0:28 bound to profile Di4
1w2d: ISDN Se1/0:15 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x792A
1w2d: Se1/0:28 DDR: Remote name for TestDATA
1w2d: Se1/0:28 DDR: dialer protocol up.
Success rate is 0 percent (0/5)
HQPRI#
1w2d: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1/0:28, changed state to up
HQPRI#ping 22.0.0.14^@
Success rate is 100 percent (5/5), round-trip min/avg/max = 164/165/172 ms
HQPRI#
1w2d: ISDN Se1/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0xF929
1w2d: ISDN Se1/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x7929
1w2d: ISDN Se1/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0xF929
1w2d: Serial1/0:15: wait for isdn carrier timeout, call id=0xF92A
1w2d: %ISDN-6-CONNECT: Interface Serial1/0:28 is now connected to 1620034912345679 TestDATA
HQPRI#
HQPRI#
1w2d: ISDN Se1/0:15 Q931: TX -> SETUP pd = 8 callref = 0x792B
Standard = CCITT
Channel ID i = 0xA9839F
Exclusive, Channel 31
1w2d: ISDN Se1/0:15 Q931: RX <- SETUP_ACK pd = 8 callref = 0xF92B
Progress Ind i = 0x8288 - In-band info or appropriate now available s caller ip
Se1/0:28 TestDATA 22.0.0.13 162003493555666 out
HQPRI#
HQPRI#
HQPRI#cle int d4
HQPRI#
1w2d: Se1/0:28 DDR: disconnecting call
1w2d: %ISDN-6-DISCONNECT: Interface Serial1/0:28 disconnected from 1620034912345679 TestDATA, call lasted 17 seconds
1w2d: ISDN Se1/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x792A
Cause i = 0x8090 - Normal call clearing
1w2d: ISDN Se1/0:15 Q931: RX <- RELEASE pd = 8 callref = 0xF92A
1w2d: %LINK-3-UPDOWN: Interface Serial1/0:28, changed state to down
1w2d: Se1/0:15 DDR: has total 0 call(s), dial_out 0, dial_in 0
1w2d: %DIALER-6-UNBIND: Interface Se1/0:28 unbound from profile Di4
1w2d: ISDN Se1/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x792A
1w2d: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1/0:28, changed state to down
HQPRI#
HQPRI#
1w2d: Se1/0:15 DDR: Dialing cause ip (s=1.5.0.2, d=192.168.10.1)
1w2d: ISDN Se1/0:15 Q931: TX -> SETUP pd = 8 callref = 0x792C
Standard = CCITT
Called Party Number i = 0x81, '16200'
1w2d: ISDN Se1/0:15 Q931: RX <- SETUP_ACK pd = 8 callref = 0xF92C
HQPRI#
HQPRI#s caller ip
HQPRI#
1w2d: ISDN Se1/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0xF92B
1w2d: ISDN Se1/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x792B
1w2d: ISDN Se1/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0xF92B
1w2d: Serial1/0:15: wait for isdn carrier timeout, call id=0xF92C
1w2d: ISDN Se1/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0xF92C
Cause i = 0x8A9C - Invalid number format (incomplete number)
1w2d: ISDN Se1/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x792C
1w2d: ISDN Se1/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0xF92C
1w2d: Serial1/0:15: wait for isdn carrier timeout, call id=0xF92D
HQPRI#
HQPRI#
HQPRI#
HQPRI#
1w2d: Se1/0:15 DDR: Attempting to dial 166400
1w2d: ISDN Se1/0:15 Q931: TX -> SETUP pd = 8 callref = 0x792D
Standard = CCITT
Re: ISDN (PRI - BRI) problem - Help required (config & debug inc
I think you are trying to use "isdn callerID callback". For that, first, you need to make sure that "callback server" OR the HQ PRI router should receive "calling party number" as 1620123666777 in the isdn SETUP message when it receives the call from BRI router. Based on that number received as callerID, the call will be binded to the "dialer interface" and will get called back.
The debug posted dosen't have incoming SETUP message on HQPRI router so can't say that the call is binded to dialer interface or not.
Now to populate the remote and local number, again, it has to be delivered at both the places via SETUP message. BRI side will know its local number because of SPID is configured on that router with LDN. PRI side will not know that.
Here is the best link which describes config and troubleshooting for "isdn callerID callback"
http://www.cisco.com/warp/public/793/access_dial/Isdn_callerID.html
We need to see the debug for
debug isdn q931/ debug ppp nego / debug dialer
on HQ PRI router when bri calls pri.
Hi there,
further debugs as promised:
HQPRI#s caller ip
Se1/0:1 RemWAN 20.0.0.1 884422 in
HQPRI#
HQPRI#
HQPRI#
HQPRI#
2w3d: ISDN Se1/0:15 Q931: RX <- SETUP_ACK pd = 8 callref = 0xC08D
277
