ISDN PRI Dialup Data with VWIC--2MFT-E1
I wan't to configure an VWIC-2MFT-E1 installed on an NM-2W for ISDN PRI
Dialup Data connections.
But there's no posibility to configure
the "tdm clock..", and the "pri-group timeslots.." command.
What must I configure to use the module
as ISDN PRI connection?
1 REPLY
Anonymous
N/A
Re: ISDN PRI Dialup Data with VWIC--2MFT-E1
The capabilities of the T1 interface
are determined by the NM it's plugged
into, and the only NM that allows
this WIC to support PRI is NM-HDV
in 12.1(3)T or higher, and even then
it is only for voice, not data.
114
