ISDN PRI (E1) interface error
admin_2
Level 3
Level 3
I have installed one port channelized E1/ISDN PRI to my Cisco 2600 router.
After install I observed that the local alarm LED (orange light ) is on.
What that means ? Do the interface have an hardware problem ?
Not applicable
The alarm means that there is a "loss
of signal, loss of frame, or unavailability
because of excessive errors".
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_mod/cis2600/hw_inst/nm_inst/nm-doc/conntpri.htm
"sh controller" should verify this, too. You may
want to confirm your framing, linecoding, physical
cabling, and work with the carrier to try some loopback
testing to try and understand where the problem
might be.
