Webcast-Catalyst9k
ISDN PRI/ISDN Bri
hi
i m getting the following error in my PRI line which ,i m trying to conenct from remoteusing an isdn line.wht could be the problem?pl;s help to identify and solve the same
ISDN PRI :
*Mar 1 18:05:51.059: ISDN Se1/0:15 EVENT: CCPRI_Go: received NL_REL_IND
*Mar 1 18:05:56.059: ISDN Se1/0:15 EVENT: Pri_Activate_L2: states = 4, 4
*Mar 1 18:06:00.059: ISDN Se1/0:15 EVENT: CCPRI_Go: received NL_REL_IND
ISDN BRI :
6d05h: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0, TEI 68 changed to up
6d05h: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0, TEI 68 changed to down
prem
1 REPLY
Re: ISDN PRI/ISDN Bri
Try to use the command "show isdn status" to check the basic status of your line. and also you can find a lot of related document by using the search function of cisco's website with the key words as "troubleshooting isdn pri/bri".
346
