10-21-2002 05:57 PM - edited 03-02-2019 02:15 AM
Dear all,
I have a central 3620 router and two remote 802s. The central is connected via ISDN PRI, the two remotes via ISDN BRI. I only want the central to dial the remotes (DDR) when required. I need assistance with the config for the remotes. Here is the critical part of the config for the central:
aaa new-model
aaa authentication login default local
aaa authentication login NO_AUTHEN none
aaa authentication ppp default local
aaa authorization network default local
username remoteisdn1 password 0 remoteisdn1
username remoteisdn2 password 0 remoteisdn2
isdn switch-type primary-5ess
controller T1 0/0
framing esf
linecode b8zs
pri-group timeslots 1-24
interface FastEthernet0/0
ip address 172.16.2.71 255.255.0.0
speed 100
full-duplex
interface Serial0/0:23
no ip address
encapsulation ppp
dialer pool-member 10 max-link 2
dialer pool-member 20 max-link 2
isdn T310 4000
no cdp enable
ppp authentication chap
ppp multilink
interface Dialer1
description For dialout ISDN connection to remoteisdn1
ip unnumbered FastEthernet0/0
encapsulation ppp
dialer pool 10
dialer remote-name remoteisdn1
dialer idle-timeout 900
dialer string 0000000000
dialer string 0000000001
dialer load-threshold 1 outbound
dialer-group 1
ppp multilink
interface Dialer2
description For dialout ISDN connection to TX - remoteisdn2
encapsulation ppp
dialer pool 20
dialer remote-name remoteisdn2
dialer string 0000000002
dialer string 0000000003
dialer-group 1
ppp multilink
router eigrp 1
passive-interface Dialer1
passive-interface Dialer2
network 172.16.0.0
no auto-summary
no eigrp log-neighbor-changes
ip classless
ip route 0.0.0.0 0.0.0.0 172.16.2.70
ip route 152.217.6.12 255.255.255.255 Dialer1
ip route 152.223.193.116 255.255.255.255 Dialer2
no ip http server
ip pim bidir-enable
access-list 101 remark Interesting traffic definition for remote ISDN links.
access-list 101 deny eigrp any any
access-list 101 permit ip any any
dialer-list 1 protocol ip permit
dialer-list 1 protocol ipx permit
line con 0
exec-timeout 0 0
login authentication NO_AUTHEN
line 33 56
modem DTR-active
modem autoconfigure type mica
rotary 1
transport input telnet
escape-character NONE
line aux 0
line vty 0 4
password password
Any help with the remote sites would be much appreciated.
Thank you,
Tony
10-22-2002 12:13 AM
Hi Tony,
the following link explains how to configure what you want.
http://www.cisco.com/warp/customer/793/access_dial/isdn800_14562.html
good luck,
Steven
