ISDN Problem ..
--begin ciscomoderator note-- The following post has been edited to remove potentially confidential information. Please refrain from posting confidential information on the site to reduce security risks to your network. -- end ciscomoderator note --
Hello Guys,
i am trying to connect to Internet via 801 and 806 (see design)
PCs
806 (PC connections with DHCP)
801 (ISDN)
The Probl is: I cann get an ip addresse from the DHCP Pool on my PC but cannot get the ISDN connection up by pinging an internet address
by using the manuel command " isdn call int bri0 0192658" i cann get the line up
cann annyone hlp me to solve this pobl ?
Thanks for any help
AF
(801)
--moderator edit-- router#sh
02:43:03: %SYS-5-CONFIG_I: Configured from console by console run
Building configuration...
Current configuration:
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname --moderator edit-- router
boot buffersize 8051
boot system flash c800-sy6-mw.121-2.T.bin
ip subnet-zero
no ip dhcp conflict logging
no ip domain-lookup
ip name-server --moderator edit-- nnn.nn.n.129
isdn switch-type basic-net3
isdn voice-call-failure 0
interface Ethernet0
ip address 10.10.10.1 255.255.255.0
ip nat inside
interface BRI0
ip address negotiated
ip nat outside
encapsulation ppp
dialer idle-timeout 180
dialer string 00192658
dialer-group 1
ppp authentication pap chap ms-chap callin
ppp chap hostname msn
ppp pap sent-username --moderator edit-- password 7 --moderator edit--
ip nat inside source list 100 interface BRI0 overload
no ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 BRI0 permanent
ip route 10.10.11.0 255.255.255.0 10.10.10.2
access-list 100 permit ip 10.10.10.0 0.0.0.255 any
dialer-list 1 protocol ip permit
line con 0
transport input none
stopbits 1
line vty 0 4
login
no rcapi server
end
(806)
--moderator edit-- firewall#sh run
Current configuration : 912 bytes
version 12.2
no service pad
hostname --moderator edit-- firewall
enable secret 5 --moderator edit--
ip subnet-zero
no ip domain-lookup
ip dhcp excluded-address 10.10.11.1
ip dhcp pool CLIENT
import all
network 10.10.11.0 255.255.255.0
dns-server --moderator edit-- nnn.nn.n.129
default-router 10.10.11.1
ip ssh time-out 120
ip ssh authentication-retries 3
crypto mib ipsec flowmib history tunnel size 200
crypto mib ipsec flowmib history failure size 200
interface Ethernet0
ip address 10.10.11.1 255.255.255.0
hold-queue 100 out
interface Ethernet1
ip address 10.10.10.2 255.255.255.0
no ip classless
ip route 0.0.0.0 0.0.0.0 10.10.10.1
no ip http server
line con 0
exec-timeout 0 0
stopbits 1
line vty 0 4
password --moderator edit--
login
scheduler max-task-time 5000
end
  • Other Network Infrastructure Subjects
Bronze
Re: ISDN Problem ..
Your config only shows 2 bri's and 2 dialers but from what I can see it might be getting confused by all those default routes. Each time another remote connects it has the capabilty of becoming the new default route and could make the others lines go idle then timeout and disconnect. Try using specific routes to each dialup network then if you dont want Ho to call the remotes remove the dailer string statements.
I would also see if you can get the phone numbers bundled into a rotary so all of the bri's can be in the same pool and all of the dialer interfaces can use that pool. Otherwise there is no point in using the dialer interfaces. You could just configure everything on the bri.
Re: ISDN Problem ..
2705 packets input, 29572 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
226 input errors, 29 CRC, 197 frame, 0 overrun, 0 ignored, 226 abort
2701 packets output, 20770 bytes, 0 underruns
There are a lot of errors on BRI 1/0 of 2600. Clear these counters, and monitor to see if they are increasing. To clear counters use command "clear counters int bri 1/0"
Re: ISDN Problem ..
First..the isdn bri line is not happy at this moment..The layer 1 is DEACTIVATED so you jst need to resolve that.
Here is the link which will help you for that.
http://www.cisco.com/warp/public/129/bri-layer1.html
For layer 2
http://www.cisco.com/warp/public/129/bri-layer2.html
Now i can see that the config is skipped..So i assume that the config is fine. With that we need to see what exactly happens when the more then two sites try to dialin. we need to see the debug for following when two calls are already connected and thrird call comes in.
debug isdn q931
debug dialer
debug ppp nego
debug ppp auth
Re: ISDN Problem ..
Hello Tejal Patel.
Here I am changing all HO and Remote (4 nos) config to point to point.
Please let me know, shall i Proced with these config.
Thanking You
Vishu
Spoke configuration :
Remote 1:
IP subnet-zero
No IP classless
ISDN switch-Type basic-net3
Hostname 801
Int Ethernet 0
IP address 175.17.0.1 255.255.0.0
Ip directed-broadcast
No cdp enable
Speed auto
Full-duflex.
Int Bri0
Ip address 172.16.0.5 255.255.0.0
Encap ppp
No cdp
Dialer-group 1
Dialer-list 1 protocol IP permit
Dialer map IP 172.16.0.1 name 2600 speed 64 broadcast 24219840
IP route 175.16.0.0 255.255.0.0 172.16.0.1
Ip route 0.0.0.0 0.0.0.0 172.16.0.1
IP route 172.16.0.1 255.255.255.255 BRI0.
Router RIP
Network 175.17.0.0
Network 172.16.0.0
Remote 2:
IP subnet-zero
No IP classless
Hostname 801
Int Ethernet 0
IP address 175.17.0.4 255.255.0.0
No cdp enable
Speed auto
Full-duflex.
Int Bri0
Ip address 172.16.0.8 255.255.0.0
Encap ppp
No cdp
Dialer-group 1
Dialer map IP 172.16.0.2 name 2600 speed 64 broadcast 24219850
IP route 175.16.0.0 255.255.0.0 172.16.0.2
IP route 172.16.0.2 255.255.255.255 BRI0.
Ip route 0.0.0.0 0.0.0.0 172.16.0.2
Router RIP
Network 175.17.0.0
Network 172.16.0.0
Remote 3:
IP subnet-zero
No IP classless
Hostname 801
Int Ethernet 0
IP address 175.17.0.3 255.255.0.0
No cdp enable
Speed auto
Full-duflex.
Int Bri0
Ip address 172.16.0.7 255.255.0.0
Encap ppp
No cdp
Dialer-group 1
Dialer map IP 172.16.0.3 name 2600 speed 64 broadcast 24219845
IP route 175.16.0.0 255.255.0.0 172.16.0.3
IP route 172.16.0.3 255.255.255.255 BRI0.
Ip route 0.0.0.0 0.0.0.0 172.16.0.3
Router RIP
Network 175.17.0.0
Network 172.16.0.0
Remote 4:
IP subnet-zero
No IP classless
Hostname 801
Int Ethernet 0
No cdp enable
Speed auto
Full-duflex.
Int Bri0
Ip address 172.16.0.6 255.255.0.0
Encap ppp
No cdp
Dialer-group 1
Dialer map IP 172.16.0.4 name 2600 speed 64 broadcast 24219855
IP route 175.16.0.0 255.255.0.0 172.16.0.4
IP route 172.16.0.4 255.255.255.255 BRI0.
Ip route 0.0.0.0 0.0.0.0 172.16.0.4
Router RIP
Network 175.17.0.0
Network 172.16.0.0
2620 config at Head office:
Hostname 2600
NO IP Classless
IP subnet-zero
ISDN switch-type basic-net3
Int Ethernet 0
Ip address 175.16.0.1 255.255.0.0
No cdp enable
Int BRI 1/0
IP address 172.16.0.1 255.255.0.0
No CDP enable
Encapsulation PPP
Dialer-group 1
Dialer-list 1 Protocol IP Permit.
Dialer map IP 175.16.0.5 name 801 speed 54 broadcast 25301915
IP route 175.17.0.1 255.255.255.255 172.16.0.5
IP route 172.16.0.5 255.255.255.255 BRI1/0
Int BRI 1/1
IP address 172.16.0.2 255.255.0.0
No CDP enable
Encapsulation PPP
Dialer-group 2
Dialer-list 2 Protocol IP Permit.
Dialer map IP 175.16.0.8 name 801 speed 54 broadcast 27613770
IP route 175.17.0.4 255.255.255.255 172.16.0.8
IP route 172.16.0.8 255.255.255.255 BRI1/1
Int BRI 1/2
IP address 172.16.0.3 255.255.0.0
No CDP enable
Encapsulation PPP
Dialer-group 3
Dialer-list 3 Protocol IP Permit.
Dialer map IP 175.16.0.7 name 801 speed 54 broadcast 28792506
IP route 175.17.0.3 255.255.255.255 172.16.0.7
IP route 172.16.0.7 255.255.255.255 BRI1/2
Int BRI 1/3
IP address 172.16.0.4 255.255.0.0
No CDP enable
Encapsulation PPP
Dialer-group 4
Dialer-list 4 Protocol IP Permit.
Dialer map IP 175.16.0.2 name 801 speed 54 broadcast 28966697
IP route 175.17.0.2 255.255.255.255 172.16.0.6
IP route 172.16.0.6 255.255.255.255 BRI1/3
Router RIP
Network 175.16.0.0
Network 172.16.0.0
looking for u r suggestions.
Re: ISDN Problem ..
IP addressing scheme is the issue here. Also no need to have telephone number configured in the dialer map at HUB site if you don't want hub site to dialout. Just use the config like following.
All the bri interfaces on HUB router should be configured like following
Int BRI 1/0
no ip address
ppp authentcation chap pap
No CDP enable
Encapsulation PPP
Dialer-group 1
dialer rotary-group 1
Now use the dialer interace config like this.
Interface dialer 1
ip address IP address 172.16.0.1 255.255.0.0
No CDP enable
Encapsulation PPP
Dialer-group 1
so instead of using individual bri interface with ip address, just use one dialer interface for all with just one ip address under the dialer interface.
Rest of the config is fine..
102
