Webcast-Catalyst9k
t1b
isdn problem
Hi all,
I have a 1750 and 1751 router setup for isdn. I can make a call from the 1751 to the 1750 with no problem, however when I make a call from the 1750 to the 1751 I get the following error:
Received a call with a bad bearer cap
Does anyone know what that means? I think long distance carrier may have the circuit setup as voice, but I am not sure.
Silver
Re: isdn problem
can you paste in a sh run from each
t1b
Re: isdn problem
Here they are:
1751
Current configuration : 1362 b
version 12.2
service timestamps debug uptim
service timestamps log datetim
hostname DCrtr
username GoshenRTR password 0
username DCrtr password 0 conn
memory-size iomem 25
clock timezone est 5
ip subnet-zero
ipx routing 0004.2722.bc3a
isdn switch-type basic-dms100
interface FastEthernet0/0
ip address 172.16.100.254 255.255.255.0
ip helper-address 172.16.10.224
speed auto
ipx network E000000F
interface Serial0/0
ip address 172.16.250.2 255.255.255.252
ipx network 2501
no fair-queue
interface BRI1/0
ip address 172.16.251.1 255.255.255.252
encapsulation ppp
dialer idle-timeout 300
dialer map ip 172.16.251.2 11232344567
dialer-group 1
isdn spid1 12312312330101 12312330101
isdn spid2 12312312340101 12312340101
isdn incoming-voice data 64
ppp authentication chap
ppp multilink
router eigrp 1
network 172.16.0.0
auto-summary
no eigrp log-neighbor-changes
ip classless
ip route 0.0.0.0 0.0.0.0 172.16.250.1
no ip http server
logging trap debugging
dialer-list 1 protocol ip permit
snmp-server community cisco RO
1750
Current configuration : 1252 bytes
version 12.1
service timestamps debug uptime
service timestamps log uptime
hostname GoshenRTR
enable secret 5 $1$mlMX$KtTNUI6Sa6WdJ5wrYPI0z1
username DCrtr password 0 connect
ip subnet-zero
no ip finger
ipx routing 0004.2722.ba2f
isdn switch-type basic-5ess
interface Serial0
ip address 172.16.250.6 255.255.255.252
ipx network 2502
interface BRI0
ip address 172.16.251.2 255.255.255.252
encapsulation ppp
dialer map ip 172.16.251.1 11231231233
dialer map ip 172.16.251.1 11231231234
dialer-group 1
isdn spid1 0123456790
isdn spid2 0123456780
ppp multilink
ip address 172.16.110.254 255.255.255.0
speed auto
ipx network 4000000A
router eigrp 1
network 172.16.0.0
auto-summary
ip classless
ip route 0.0.0.0 0.0.0.0 172.16.250.5
no ip http server
snmp-server community ciscocisco RW
line con 0
transport input none
line aux 0
line vty 0 4
Re: isdn problem
Can you paste outputs of a debug isdn q931 on this router ? Dont give the debug during peak hours. ( it can hamper router performance)
t1b
Re: isdn problem
Here is the 1750, it is the one initiating the call:
30w6d: ISDN BR0: TX -> SETUP pd = 8 callref = 0x1F
30w6d: Bearer Capability i = 0x8890
30w6d: Channel ID i = 0x83
30w6d: Keypad Facility i = '11231231234'
30w6d: ISDN BR0: RX <- CALL_PROC pd = 8 callref = 0x9F
30w6d: Channel ID i = 0x89...
30w6d: ISDN BR0: RX <- PROGRESS pd = 8 callref = 0x9F
30w6d: Progress Ind i = 0xC48A - Delay in response at called interface
30w6d: Signal i = 0x01 - Ring back tone on
30w6d: ISDN BR0: HOST_PROGRESS: Got IE of INBAND or Not End-To-End.
30w6d: ISDN BR0: RX <- DISCONNECT pd = 8 callref = 0x9F
30w6d: Cause i = 0x8492 - No user responding
30w6d: ISDN BR0: TX -> RELEASE pd = 8 callref = 0x1F
30w6d: Cause i = 0x8090 - Normal call clearing
30w6d: ISDN BR0: TX -> SETUP pd = 8 callref = 0x20
30w6d: ISDN BR0: RX <- RELEASE_COMP pd = 8 callref = 0x9F
30w6d: ISDN BR0: RX <- CALL_PROC pd = 8 callref = 0xA0
Success rate is 0 percent (0/5)
GoshenRTR#u
30w6d: ISDN BR0: RX <- PROGRESS pd = 8 callref = 0xA0
30w6d: ISDN BR0: HOST_PROGRESS: Got IE of INBAND or Not End-To-Endndebug a
30w6d: ISDN BR0: RX <- DISCONNECT pd = 8 callref = 0xA0
30w6d: ISDN BR0: TX -> RELEASE pd = 8 callref = 0x20
30w6d: ISDN BR0: RX <- RELEASE_COMP pd = 8 callref = 0xA0
Here is the 1751, the receiving router:
6d20h: ISDN BR1/0 Q931: RX <- SETUP pd = 8 callref = 0x53
Standard = CCITT
Transer Capability = Unrestricted Digital
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x89
Signal i = 0x40 - Alerting on - pattern 0
Calling Party Number i = 0x21, 0x83, '2342342345'
Plan:ISDN, Type:National
Called Party Number i = 0xC1, '1231233'
Plan:ISDN, Type:Subscriber(local)
6d20h: ISDN BR1/0 **ERROR**: host_incoming_call: Received a call with a bad bearer cap from 2342342345 on B1
Standard = CCITT
Channel ID i = 0x89
Locking Shift to Codeset 5
Codeset 5 IE 0x2A i = 0x808001038D0E, 'COMPANY NAME', 0x8001038B0C, '
845 294-6253', 0x8001088001, '('
6d20h: ISDN BR1/0 Q931: RX <- SETUP pd = 8 callref = 0x54
Standard = CCITT
Channel ID i = 0x89
Called Party Number i = 0xC1, '1231234'
Standard = CCITT
Channel ID i = 0x89
234 234-2345', 0x8001088001, '('
Re: isdn problem
I think, you should verify the number that's being called by the 1750 with the service provider. The error code 0x8492 (: Cause i = 0x8492 - No user responding ) denotes that the number the 1750 dialed is not reachable. You should check the number you have configured as well as whether that number is a valid one. Also check if you need to dial a 9 (for the pbx) or a 1010220, because the number you might be calling needs a long distance code to be prefixed.
t1b
Re: isdn problem
I don't think that is the problem. The call makes it to the other router, but it won't connect because of "bad bearer cap". If I make a voice call to the number, I get the same error message, even though the call is never connected.
Silver
Re: isdn problem
try a map class to force 56K some legacy switches will nnot support 64K
global
map-class dialer test
dialer isdn speed 56
on the interface
dialer string 5551212 class test
Bronze
Re: isdn problem
This error usually indcates a discrepency between how the line has been configured and how it was provisioned. It think you need to remove the "isdn incomng-voice data 64" statement from the 1751. It is receiving calls on a line that is not capable of carrying voice calls but it is configured to handle voice calls.
t1b
Re: isdn problem
I tend to agree with you about the provisioning. I added the incoming-voice statement as a test. I am contacting the provider now to make sure it is done correctly. To me it looks like the call is coming in as a voice call not data. The calling router says it is a "data" call so I am thinking the receiving switch is the problem.
278
