ISDN Problem
Anyone got any idea what this means?
CCB:callid=80F1, sapi=0, ces=0, B-chan=31, calltype=DATA, hdlctype=HDLC-TRUNK
I have configured ISDN and seem to be getting the above on my layer 3. For ref please see the output from various commands.
# sh isdn status
Global ISDN Switchtype = primary-net5
ISDN Serial1/0:15 interface
dsl 0, interface ISDN Switchtype = primary-net5
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 1
The Free Channel Mask: 0xBFFF7FFF
Number of L2 Discards = 0, L2 Session ID = 2
Total Allocated ISDN CCBs = 1
sh run
Building configuration...
Current configuration : 3922 bytes
controller E1 1/0
framing NO-CRC4
pri-group timeslots 1-31
interface Serial1/0:15
description local ISDN number tba
no ip address
ip access-group 143 in
encapsulation ppp
dialer pool-member 1
isdn switch-type primary-net5
no cdp enable
ppp authentication chap
interface Dialer1
ip address x.x.x.x x.x.x.x
encapsulation ppp
dialer pool 1
dialer remote-name xxxxxxxx
dialer string xxxxxxxx
dialer load-threshold 128 outbound
dialer watch-group 1
dialer-group 1
no cdp enable
ppp chap hostname xxxxxxxxx
ppp multilink
sh int s1/0:15
Serial1/0:15 is up, line protocol is up (spoofing)
Hardware is DSX1
Description: local ISDN number tba
MTU 1500 bytes, BW 64 Kbit, DLY 20000 usec,
reliability 255/255, txload 19/255, rxload 7/255
Encapsulation PPP, loopback not set
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 00:11:40
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 4
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/1/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 48 kilobits/sec
5 minute input rate 2000 bits/sec, 37 packets/sec
5 minute output rate 5000 bits/sec, 37 packets/sec
21791 packets input, 185161 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
21801 packets output, 392172 bytes, 0 underruns
1 carrier transitions
sh controllers e1 1/0
E1 1/0 is up.
Applique type is Channelized E1 - balanced
No alarms detected.
alarm-trigger is not set
Framing is NO-CRC4, Line Code is HDB3, Clock Source is Line.
Data in current interval (872 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 1 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 1 Severely Err Secs, 0 Unavail Secs
Any bit of information will be great help.
Thank you in advance.
Cheers
Jay
1 REPLY
Bronze
Re: ISDN Problem
As such from the show isdn status , your line is not have no problem , its explains caller Id , calltype =voice/data, encapsulation=PPP/HDLC, which channel is currehtly is used . If you are interesting to troubleshooting E1 you can use these links
http://www.cisco.com/warp/public/116/T1_pri.html
http://www.cisco.com/en/US/tech/tk713/tk628/technologies_tech_note09186a00800a70fb.shtml
http://www.cisco.com/en/US/tech/tk713/tk628/technologies_tech_note09186a00801509d7.shtml
http://www.cisco.com/warp/public/129/bri_sh_isdn_stat.html#spid
286
