Community Member
isdn problems
We have some problems dialing in remotely.
Here are some debug:
Any ideas?
6d13h: ISDN BR1/0: Recvd MPH_IIC_IND from L1
6d13h: ISDN BR1/0: L1 is IF_ACTIVE
6d13h: ISDN BR1/0 EVENT: isdn_sw_cstate: State = 4, Old State = 4
6d13h: ISDN BR1/0: Incoming call id = 0x0091, dsl 8
6d13h: ISDN BR1/0: TX -> IDREQ ri=52686 ai=127
6d13h: ISDN BR1/0: RX <- IDASSN ri=52686 ai=66
6d13h: ISDN BR1/0: TX -> SABMEp c/r=0 sapi=0 tei=66
6d13h: ISDN BR1/0: RX <- UAf c/r=0 sapi=0 tei=66
6d13h: %ISDN-6-LAYER2UP: Layer 2 for Interface BR1/0, TEI 66 changed to up
6d13h: ISDN BR1/0: RX <- UI c/r=1 sapi=0 tei=127 i=0x08013505A1040288901801896C0B2183323036323634323830700AA1323036383933393130
6d13h: SETUP pd = 8 callref = 0x35
6d13h: Sending Complete
6d13h: Bearer Capability i = 0x8890
6d13h: Channel ID i = 0x89
6d13h: Calling Party Number i = 0x21, 0x83, '206264280', Plan:ISDN, Type:National
6d13h: Called Party Number i = 0xA1, '206893910', Plan:ISDN, Type:National
6d13h: CCBRI_Go Fr L3 pkt (Len=37) :
6d13h: 5 1 B5 90 A1 4 2 88 90 18 1 89 6C B 21 83 32 30 36 32 36 34 32 38 30 70 A A1 32 30 36 38 39 33 39 31 30
6d13h:
6d13h: ISDN BR1/0: Incoming call id = 0x0092, dsl 8
6d13h: ISDN BR1/0: LIF_EVENT: ces/callid 1/0x92 HOST_INCOMING_CALL
6d13h: ISDN BR1/0: HOST_INCOMING_CALL: (non-POTS) DATA
6d13h: ISDN BR1/0: HOST_INCOMING_CALL: (1) call_type = DATA
6d13h: ISDN BR1/0: HOST_INCOMING_CALL: voice_answer_data = FALSE call type is DATA
6d13h: ISDN BR1/0: Event: Received a DATA call from 206264280 on B1 at 64 Kb/s
6d13h: ISDN BR1/0: Event: Accepting the call id 0x92
6d13h: %DIALER-6-BIND: Interface BR1/0:1 bound to profile Di1
6d13h: ISDN BR1/0: RM returned call_type 0 resource type 0 response 1
6d13h: CCBRI_Go Fr Host InPkgInfo (Len=9) :
6d13h: 7 8 1 0 92 3 18 1 89
6d13h:
6d13h: ISDN BR1/0: isdn_send_connect(): msg 4, call id 0x92, ces 1 bchan 0, call type DATA
6d13h: %LINK-3-UPDOWN: Interface BRI1/0:1, changed state to up
6d13h: ISDN: get_isdn_service_state(): idb 0x80FC0010 bchan 2 is_isdn 1 Not a Pri
6d13h: BR1/0:1 PPP: Treating connection as a callin
6d13h: BR1/0:1 PPP: Phase is ESTABLISHING, Passive Open [0 sess, 0 load]
6d13h: BR1/0:1 LCP: State is Listen
6d13h: CCBRI_Go Fr Host InPkgInfo (Len=6) :
6d13h: 4 8 1 0 92 0
6d13h:
6d13h: ISDN BR1/0: TX -> INFOc sapi=0 tei=66 ns=0 nr=0 i=0x0801B502180189
6d13h: CALL_PROC pd = 8 callref = 0xB5
6d13h: ISDN BR1/0: RX <- RRr sapi=0 tei=66 nr=1
6d13h: ISDN BR1/0: TX -> INFOc sapi=0 tei=66 ns=1 nr=0 i=0x0801B507
6d13h: CONNECT pd = 8 callref = 0xB5
6d13h: ISDN BR1/0: RX <- RRr sapi=0 tei=66 nr=2
6d13h: ISDN BR1/0: RX <- INFOc sapi=0 tei=66 ns=0 nr=2 i=0x0801350F
6d13h: CONNECT_ACK pd = 8 callref = 0x35
6d13h: ISDN BR1/0: TX -> RRr sapi=0 tei=66 nr=1
6d13h: CCBRI_Go Fr L3 pkt (Len=4) :
6d13h: F 1 B5 92
6d13h:
6d13h: ISDN BR1/0: LIF_EVENT: ces/callid 1/0x92 HOST_CONNECT
6d13h: ISDN BR1/0: Event: Connected to 206264280 on B1 at 64 Kb/s
6d13h: BR1/0:1 LCP: I CONFREQ [Listen] id 11 len 12
6d13h: BR1/0:1 LCP: MRU 2048 (0x01040800)
6d13h: BR1/0:1 LCP: PFC (0x0702)
6d13h: BR1/0:1 LCP: ACFC (0x0802)
6d13h: BR1/0:1 LCP: O CONFREQ [Listen] id 115 len 15
6d13h: BR1/0:1 LCP: AuthProto CHAP (0x0305C22305)
6d13h: BR1/0:1 LCP: MagicNumber 0x2AC22101 (0x05062AC22101)
6d13h: BR1/0:1 LCP: O CONFACK [Listen] id 11 len 12
6d13h: BR1/0:1 LCP: I CONFREJ [ACKsent] id 115 len 10
6d13h: BR1/0:1 LCP: O CONFREQ [ACKsent] id 116 len 9
6d13h: BR1/0:1 LCP: I CONFACK [ACKsent] id 116 len 9
6d13h: BR1/0:1 LCP: State is Open
6d13h: BR1/0:1 PPP: Phase is AUTHENTICATING, by this end [0 sess, 0 load]
6d13h: BR1/0:1 CHAP: O CHALLENGE id 58 len 28 from "imcrar1"
6d13h: BR1/0:1 CHAP: I RESPONSE id 58 len 24 from "rts"
6d13h: BR1/0:1 CHAP: O SUCCESS id 58 len 4
6d13h: BR1/0:1 PPP: Phase is UP [0 sess, 0 load]
6d13h: BR1/0:1 IPCP: O CONFREQ [Not negotiated] id 58 len 10
6d13h: BR1/0:1 IPCP: Address 192.168.170.1 (0x0306C0A8AA01)
6d13h: ISDN BR1/0: Event: Hangup call to call id 0x92
6d13h: ISDN BR1/0: process_disconnect(): call id 0x92, call type is DATA, b_idb 0x80FC0010, ces 1, cause Normal call clearing(0x10)
6d13h: %ISDN-6-CONNECT: Interface BRI1/0:1 is now connected to 206264280 rts
imcrar1#
6d13h: CCBRI_Go Fr Host InPkgInfo (Len=13) :
6d13h: 5 8 1 0 92 3 8 1 90 8 2 80 90
6d13h:
6d13h: ISDN BR1/0: TX -> INFOc sapi=0 tei=66 ns=2 nr=1 i=0x0801B54508028090
6d13h: DISCONNECT pd = 8 callref = 0xB5
6d13h: Cause i = 0x8090 - Normal call clearing
6d13h: ISDN BR1/0: RX <- RRr sapi=0 tei=66 nr=3
6d13h: ISDN BR1/0: RX <- INFOc sapi=0 tei=66 ns=1 nr=3 i=0x0801354D08028090
6d13h: RELEASE pd = 8 callref = 0x35
6d13h: ISDN BR1/0: TX -> RRr sapi=0 tei=66 nr=2
6d13h: CCBRI_Go Fr L3 pkt (Len=8) :
6d13h: 4D 1 B5 97 8 2 80 90
6d13h:
6d13h: ISDN BR1/0: LIF_EVENT: ces/callid 1/0x92 HOST_DISCONNECT_ACK
6d13h: ISDN BR1/0: HOST_DISCONNECT_ACK: call type is DATA
6d13h: %LINK-3-UPDOWN: Interface BRI1/0:1, changed state to down
6d13h: BR1/0:1 IPCP: State is Closed
6d13h: BR1/0:1 PPP: Phase is TERMINATING [0 sess, 0 load]
6d13h: BR1/0:1 LCP: State is Closed
6d13h: BR1/0:1 PPP: Phase is DOWN [0 sess, 0 load]
6d13h: %DIALER-6-UNBIND: Interface BR1/0:1 unbound from profile Di1
imcrar1#
6d13h: ISDN BR1/0: TX -> INFOc sapi=0 tei=66 ns=3 nr=2 i=0x0801B55A
6d13h: RELEASE_COMP pd = 8 callref = 0xB5
6d13h: ISDN BR1/0: RX <- RRr sapi=0 tei=66 nr=4
6d13h: ISDN BR1/0: RX <- UI c/r=1 sapi=0 tei=127 i=0x08013605A10402889018018A6C0B2183323036323634323830700AA1323036383933393130
6d13h: SETUP pd = 8 callref = 0x36
6d13h: Channel ID i = 0x8A
6d13h: 5 1 B6 90 A1 4 2 88 90 18 1 8A 6C B 21 83 32 30 36 32 36 34 32 38 30 70 A A1 32 30 36 38 39 33 39 31 30
6d13h:
6d13h: ISDN BR1/0: Incoming call id = 0x0093, dsl 8
6d13h: ISDN BR1/0: LIF_EVENT: ces/callid 1/0x93 HOST_INCOMING_CALL
6d13h: ISDN BR1/0: Event: Received a DATA call from 206264280 on B2 at 64 Kb/s
6d13h: ISDN BR1/0: Event: Accepting the call id 0x93
6d13h: %DIALER-6-BIND: Interface BR1/0:2 bound to profile Di1
6d13h: 7 8 1 0 93 3 18 1 8A
6d13h:
6d13h: ISDN BR1/0: isdn_send_connect(): msg 4, call id 0x93, ces 1 bchan 1, call type DATA
6d13h: %LINK-3-UPDOWN: Interface BRI1/0:2, changed state to up
6d13h: ISDN: get_isdn_service_state(): idb 0x80FC327C bchan 3 is_isdn 1 Not a Pri
6d13h: BR1/0:2 PPP: Treating connection as a callin
6d13h: BR1/0:2 PPP: Phase is ESTABLISHING, Passive Open [0 sess, 0 load]
6d13h: BR1/0:2 LCP: State is Listen
6d13h: 4 8 1 0 93 0
6d13h:
6d13h: ISDN BR1/0: TX -> INFOc sapi=0 tei=66 ns=4 nr=2 i=0x0801B60218018A
6d13h: CALL_PROC pd = 8 callref = 0xB6
6d13h: ISDN BR1/0: RX <- RRr sapi=0 tei=66 nr=5
6d13h: ISDN BR1/0: TX -> INFOc sapi=0 tei=66 ns=5 nr=2 i=0x0801B607
6d13h: CONNECT pd = 8 callref = 0xB6
6d13h: ISDN BR1/0: RX <- RRr sapi=0 tei=66 nr=6
6d13h: ISDN BR1/0: RX <- INFOc sapi=0 tei=66 ns=2 nr=6 i=0x0801360F
6d13h: CONNECT_ACK pd = 8 callref = 0x36
6d13h: ISDN BR1/0: TX -> RRr sapi=0 tei=66 nr=3
6d13h: F 1 B6 92
6d13h:
6d13h: ISDN BR1/0: LIF_EVENT: ces/callid 1/0x93 HOST_CONNECT
6d13h: ISDN BR1/0: Event: Connected to 206264280 on B2 at 64 Kb/s
6d13h: BR1/0:2 LCP: I CONFREQ [Listen] id 20 len 12
6d13h: BR1/0:2 LCP: MRU 2048 (0x01040800)
6d13h: BR1/0:2 LCP: PFC (0x0702)
6d13h: BR1/0:2 LCP: ACFC (0x0802)
6d13h: BR1/0:2 LCP: O CONFREQ [Listen] id 117 len 15
6d13h: BR1/0:2 LCP: AuthProto CHAP (0x0305C22305)
6d13h: BR1/0:2 LCP: MagicNumber 0x2AC22923 (0x05062AC22923)
6d13h: BR1/0:2 LCP: O CONFACK [Listen] id 20 len 12
6d13h: BR1/0:2 LCP: I CONFREJ [ACKsent] id 117 len 10
6d13h: BR1/0:2 LCP: O CONFREQ [ACKsent] id 118 len 9
6d13h: BR1/0:2 LCP: I CONFACK [ACKsent] id 118 len 9
6d13h: BR1/0:2 LCP: State is Open
6d13h: BR1/0:2 PPP: Phase is AUTHENTICATING, by this end [0 sess, 0 load]
6d13h: BR1/0:2 CHAP: O CHALLENGE id 59 len 28 from "imcrar1"
6d13h: BR1/0:2 CHAP: I RESPONSE id 59 len 24 from "rts"
6d13h: BR1/0:2 CHAP: O SUCCESS id 59 len 4
6d13h: BR1/0:2 PPP: Phase is UP [0 sess, 0 load]
6d13h: BR1/0:2 IPCP: O CONFREQ [Not negotiated] id 59 len 10
6d13h: BR1/0:2 IPCP: Address 192.168.170.1 (0x0306C0A8AA01)
6d13h: ISDN BR1/0: Event: Hangup call to call id 0x93
6d13h: ISDN BR1/0: process_disconnect(): call id 0x93, call type is DATA, b_idb 0x80FC327C, ces 1, cause Normal call clearing(0x10)
6d13h: %ISDN-6-CONNECT: Interface BRI1/0:2 is now connected to 206264280 rts
6d13h: 5 8 1 0 93 3 8 1 90 8 2 80 90
6d13h:
6d13h: ISDN BR1/0: TX -> INFOc sapi=0 tei=66 ns=6 nr=3 i=0x0801B64508028090
6d13h: DISCONNECT pd = 8 callref = 0xB6
6d13h: ISDN BR1/0: RX <- RRr sapi=0 tei=66 nr=7
6d13h: ISDN BR1/0: RX <- INFOc sapi=0 tei=66 ns=3 nr=7 i=0x0801364D08028090
6d13h: RELEASE pd = 8 callref = 0x36
6d13h: ISDN BR1/0: TX -> RRr sapi=0 tei=66 nr=4
6d13h: 4D 1 B6 97 8 2 80 90
6d13h:
6d13h: ISDN BR1/0: LIF_EVENT: ces/callid 1/0x93 HOST_DISCONNECT_ACK
6d13h: %LINK-3-UPDOWN: Interface BRI1/0:2, changed state to down
6d13h: BR1/0:2 IPCP: State is Closed
6d13h: BR1/0:2 PPP: Phase is TERMINATING [0 sess, 0 load]
6d13h: BR1/0:2 LCP: State is Closed
6d13h: BR1/0:2 PPP: Phase is DOWN [0 sess, 0 load]
6d13h: %DIALER-6-UNBIND: Interface BR1/0:2 unbound from profile Di1
imcrar1#
6d13h: ISDN BR1/0: TX -> INFOc sapi=0 tei=66 ns=7 nr=4 i=0x0801B65A
6d13h: RELEASE_COMP pd = 8 callref = 0xB6
6d13h: ISDN BR1/0: RX <- RRr sapi=0 tei=66 nr=8
6d13h: ISDN BR1/1: TX -> RRp sapi=0 tei=96 nr=0
6d13h: ISDN BR1/1: RX <- RRf sapi=0 tei=96 nr=0
6d13h: ISDN BR1/1: RX <- RRp sapi=0 tei=96 nr=0
6d13h: ISDN BR1/1: TX -> RRf sapi=0 tei=96 nr=0
6d13h: ISDN BR1/2: TX -> RRp sapi=0 tei=80 nr=0
6d13h: ISDN BR1/2: RX <- RRf sapi=0 tei=80 nr=0
6d13h: ISDN BR1/2: RX <- RRp sapi=0 tei=80 nr=0
6d13h: ISDN BR1/2: TX -> RRf sapi=0 tei=80 nr=0
6d13h: ISDN BR1/3: TX -> RRp sapi=0 tei=64 nr=0
6d13h: ISDN BR1/3: RX <- RRf sapi=0 tei=64 nr=0
imcrar1#
6d13h: ISDN BR1/3: RX <- RRp sapi=0 tei=64 nr=0
6d13h: ISDN BR1/3: TX -> RRf sapi=0 tei=64 nr=0
6d13h: ISDN BR1/0: RX <- UI c/r=1 sapi=0 tei=127 i=0x08013705A1040288901801896C0B2183323036323634323830700AA1323036383933393130
6d13h: SETUP pd = 8 callref = 0x37
6d13h: 5 1 B7 90 A1 4 2 88 90 18 1 89 6C B 21 83 32 30 36 32 36 34 32 38 30 70 A A1 32 30 36 38 39 33 39 31 30
6d13h:
6d13h: ISDN BR1/0: Incoming call id = 0x0094, dsl 8
6d13h: ISDN BR1/0: LIF_EVENT: ces/callid 1/0x94 HOST_INCOMING_CALL
6d13h: ISDN BR1/0: Event: Accepting the call id 0x94
6d13h: 7 8 1 0 94 3 18 1 89
6d13h:
6d13h: ISDN BR1/0: isdn_send_connect(): msg 4, call id 0x94, ces 1 bchan 0, call type DATA
6d13h: 4 8 1 0 94 0
6d13h:
6d13h: ISDN BR1/0: TX -> INFOc sapi=0 tei=66 ns=8 nr=4 i=0x0801B702180189
6d13h: CALL_PROC pd = 8 callref = 0xB7
6d13h: ISDN BR1/0: RX <- RRr sapi=0 tei=66 nr=9
6d13h: ISDN BR1/0: TX -> INFOc sapi=0 tei=66 ns=9 nr=4 i=0x0801B707
6d13h: CONNECT pd = 8 callref = 0xB7
6d13h: ISDN BR1/0: RX <- RRr sapi=0 tei=66 nr=10
6d13h: ISDN BR1/0: RX <- INFOc sapi=0 tei=66 ns=4 nr=10 i=0x0801370F
6d13h: CONNECT_ACK pd = 8 callref = 0x37
6d13h: ISDN BR1/0: TX -> RRr sapi=0 tei=66 nr=5
6d13h: F 1 B7 92
6d13h:
6d13h: ISDN BR1/0: LIF_EVENT: ces/callid 1/0x94 HOST_CONNECT
6d13h: BR1/0:1 LCP: I CONFREQ [Listen] id 229 len 12
6d13h: BR1/0:1 LCP: O CONFREQ [Listen] id 117 len 15
6d13h: BR1/0:1 LCP: MagicNumber 0x2AC2333A (0x05062AC2333A)
6d13h: BR1/0:1 LCP: O CONFACK [Listen] id 229 len 12
6d13h: BR1/0:1 LCP: I CONFREJ [ACKsent] id 117 len 10
6d13h: BR1/0:1 LCP: O CONFREQ [ACKsent] id 118 len 9
6d13h: BR1/0:1 LCP: I CONFACK [ACKsent] id 118 len 9
imcrar1#
6d13h: BR1/0:1 CHAP: O CHALLENGE id 59 len 28 from "imcrar1"
6d13h: BR1/0:1 CHAP: I RESPONSE id 59 len 24 from "rts"
6d13h: BR1/0:1 CHAP: O SUCCESS id 59 len 4
6d13h: BR1/0:1 IPCP: O CONFREQ [Closed] id 59 len 10
6d13h: ISDN BR1/0: Event: Hangup call to call id 0x94
6d13h: ISDN BR1/0: process_disconnect(): call id 0x94, call type is DATA, b_idb 0x80FC0010, ces 1, cause Normal call clearing(0x10)
6d13h: 5 8 1 0 94 3 8 1 90 8 2 80 90
1 REPLY
Community Member
Re: isdn problems
To me your problem seems to come from th IP Control Protocol which is not negotiated correctly, I would have to see parts of your configs to tell you more.
152
