06-18-2002 08:48 AM - edited 03-01-2019 10:15 PM
Hi All
I have an external company wanting to dial into our company's router, via their router over isdn. I want to be able to allocate them an ip address and keep their config on their router as minimal as possible ie; on their router, the ip address will be negotiated from mine etc. Can this be done and has anyone got a sample config.
06-19-2002 03:11 AM
H i All
I am going to do the standard config and keep it simple.
All sorted.
Regards to all
06-19-2002 05:32 AM
interface Serial3/0:15
ip address 172.16.32.2 255.255.255.0
encapsulation ppp
dialer idle-timeout 0
isdn switch-type primary-net5
isdn incoming-voice modem
no cdp enable
peer default ip address pool mypool
ppp authentication pap callin
ppp multilink
this is a simple configuration.You can give addresses dynamically from an address-pool
06-19-2002 06:18 AM
Here are the urls which discuss that in detail.
If you have a pri line on the router
http://www.cisco.com/warp/public/793/access_dial/t1_dialin_5412.html
http://www.cisco.com/warp/public/129/15.html
If you have bri line
http://www.cisco.com/warp/public/793/access_dial/ddr_dialer_profile.html
