ISDN top-up for WAN circuit
m.tapping
Is it possible to use a 'top-up' of ISDN2 based on load for a point-point synchronous serial connection? If so can this co-exist as a back-up route using 'floating static' or is a seperate dialer interface required?
bbranch
Level 3
Level 3
You can use the backup load command on your serial interface in conjunction with the backup interface command
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fdial_c/fnsprt6/dcdbaks.htm#xtocid9
bbranch
Level 3
Level 3
