Community Member
isdn using 2 bri going to 1 bri
i am using 2 bri for data but when a voice call is made i want to use 1 bri for data and 1 bri for voice call.
please, what shell i do - the bri configuration is attached:
version 12.0
no service pad
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
hostname br-isdn
logging buffered 8192 debugging
aaa new-model
aaa authentication login default local
aaa authentication ppp default local
enable password 7
username as5200 password 7
clock timezone ISRAEL 2
clock summer-time ISRAEL date Apr 8 2001 1:59 Sep 21 2001 1:59
dial-peer voice 1 pots
no forward-to-unused-port
call-waiting
ring 0
port 1
destination-pattern 039246522
dial-peer voice 2 pots
call-waiting
ring 0
port 2
destination-pattern 039246532
ip subnet-zero
ip domain-name ta.ladpc.gov.il
ip name-server 10.236.10.1
isdn switch-type basic-net3
process-max-time 200
interface Ethernet0
ip address 10.56.56.254 255.255.255.0
no ip directed-broadcast
interface BRI0
description phone
ip address negotiated
encapsulation ppp
dialer idle-timeout 3600
dialer string 9275000
dialer load-threshold 1 either
dialer-group 1
isdn voice-priority 9246522 out always
isdn voice-priority 9246522 in always
isdn voice-priority 039246522 in always
isdn voice-priority 039246522 out always
isdn voice-priority 039246532 in always
isdn voice-priority 039246532 out always
isdn voice-priority 9246532 out always
isdn voice-priority 9246532 in always
isdn incoming-voice modem
ppp authentication chap
ppp chap hostname br_isdn
ppp chap password 7
ppp multilink
ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 BRI0
dialer-list 1 protocol ip permit
line con 0
transport input none
stopbits 1
line vty 0 4
exec-timeout 15 0
sntp server 10.227.236.1
end
br-isdn#
Community Member
Re: isdn using 2 bri going to 1 bri
The only thing that I can see is the dialer load-threshold 1 which should be set higher. Please try to change this and see how you go.
Community Member
The dialer load-threshold set to 1 only just for triger the bri more quickly
93
