Issue configuring 837 - ADSL PPPoA with SDM
My problem is that SDM does not show the correct option for a PPPoA connection. Only PPPoE, RFC 1483 SNAP, RFC 1483 MUX.
If I choose RFC 1483 SNAP or MUX, I cannot see where to input the username and password. And, as a result of this, I cannot connect to my ISP. Has anyone successfully used SDM to setup a PPPoA connection?
Thanks in advance
Nick
P.S: I am based in the UK, and can connect to my ISP if I use CRWS. CRWS does give a PPPoA option, and a place to input a username and password.
1 ACCEPTED SOLUTION
Silver
Re: Issue configuring 837 - ADSL PPPoA with SDM
We cann't configure PPPoA connection using SDM. But we can configure PPPoA in 837 router by manually configuring encapsulation "aal5mux" under the ATM interface. Here the following link helps you to configure it(eventhough it is for 827, same applies to 837).
http://www.cisco.com/en/US/products/hw/routers/ps380/products_configuration_example09186a00800940b9.shtml
Silver
The current release of SDM does not support PPPoA. Confirmed this with Cisco TAC.
As you suggest, the only workaround at the moment is to configure manually with the CLI.
Anonymous
N/A
Actually what I did was to configure my ADSL Connection via CRWS and then switch to SDM without following the first line of commands (i didn't use the sdm default config).
Router# copy sdmconfig-83x.cfg start <<--- I skipped this line
Router# copy sdm.shtml.hide nvram:sdm.shtml
Router# copy nvram:sdm.shtml flash:sdm.shtml
Router# copy home.html.hide nvram:home.html
Router# copy nvram:home.html flash:home.html
Router# delete nvram:sdm.shtml
Router# delete nvram:home.html
Router# reload
So now I have my adsl connection up, and I'm using SDM.
But theres a problem with the 111 access list which I dont get to work since SDM says its read only... :(
471
