Community Member
Issue configuring Soho97 - ADSL with pppoa
I'm trying to configure my soho97 router with adsl, but it doesn't works. I'm in the UK with a fixed IP address and using pppoa, chap, vc-mux and pvc 0/38.
from the internal lan I can ping int e0(10.10.10.1) and int d1(82.x.x.x) with no issues, but 1 cannot the isp’s dns server 212.23.8.1.
from the router console I can only ping 10.10.10.1 with success. int d1 and isp dns no good..
Sample below
Building configuration...
Current configuration : 1685 bytes
version 12.3
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname RouterSOHO97
ip subnet-zero
ip name-server 212.x.8.1
ip name-server 212.23.8.6
ip dhcp excluded-address 10.10.10.1
ip dhcp pool CLIENT
network 10.10.10.0 255.255.255.0
default-router 10.10.10.1
dns-server 212.x.x.x.23.8.6
lease 0 2
no aaa new-model
interface Ethernet0
ip address 10.10.x.x.255.255.0
ip nat inside
ip tcp adjust-mss 1452
hold-queue 100 out
interface ATM0
no ip address
atm vc-per-vp 128
no atm ilmi-keepalive
pvc 0/38
encapsulation aal5mux ppp dialer
dsl operating-mode auto
interface Dialer1
ip address 82.x.x.x 255.255.255.248
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname xxxxxx
ppp chap password xxxx
ppp pap sent-username xxxxxx password xxxx!
ip nat inside source list 102 interface Dialer1 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
ip http server
no ip http secure-server
access-list 23 permit 10.10.10.0 0.0.0.255
access-list 102 permit ip 10.10.10.0 0.0.0.255 any
dialer-list 1 protocol ip permit
line con 0
exec-timeout 120 0
no modem enable
stopbits 1
line aux 0
line vty 0 4
access-class 23 in
exec-timeout 120 0
login local
length 0
scheduler max-task-time 5000
End
Below some diags samples;
show int atm 0
ATM0 is up, line protocol is up
Hardware is PQUICC_SAR (with Alcatel ADSL Module)
MTU 1500 bytes, sub MTU 1500, BW 288 Kbit, DLY 80 usec,
reliability 68/255, txload 1/255, rxload 1/255
Encapsulation ATM, loopback not set
Encapsulation(s): AAL5 AAL2, PVC mode
10 maximum active VCs, 128 VCs per VP, 1 current VCCs
VC Auto Creation Disabled.
VC idle disconnect time: 300 seconds
Last input never, output 00:14:02, output hang never
Queueing strategy: Per VC Queueing
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
16 packets output, 1120 bytes, 0 underruns
0 output errors, 0 collisions, 3 interface resets
RouterSOHO97#
sh atm int atm0
Interface ATM0:
AAL enabled: AAL5 AAL2, Maximum VCs: 10, Current VCCs: 1
Maximum Transmit Channels: 0
VCIs per VPI: 128,
Max. Datagram Size: 1528
PLIM Type: ADSL - 800Kbps Upstream, DMT, TX clocking: LINE
0 input, 16 output, 0 IN fast, 0 OUT fast
Avail bw = 800
Config. is ACTIVE
RouterSOHO97#
sh ip int bri
ATM0 unassigned YES NVRAM up up
Dialer1 82.x.x.x YES manual up up
Ethernet0 10.10.10.1 YES NVRAM up up
RouterSOHO97#
Sorry for the large amount of info. hopefully it will help solve my problems..
Thanx
VIP Purple
Re: Issue configuring Soho97 - ADSL with pppoa
from what I can see you need to bind your ATM interface to your dialer:
interface ATM0
no ip address
atm vc-per-vp 128
pvc 0/38
-->dialer pool-member 1
Can you add this to your configuration and see if it works ?
GP
Community Member
GP,
Thanks for your advice.
I have tried your suggestion and I still have the same symptons??
Community Member
further on from that i ran "debug ppp negotiation" and i attached the output. there is an Authentication failure. could this be the isp issue.
thanks in advance
Community Member
Thanks for all your help.
It wasn't anything to with my configs. My account was incorrectly configured at my ISP.
nickymo
112
