Issue with Catalyst C3550 forwarding Client DHCP Requests
Are there any known issues with the Catalyst 3550 forwarding DHCP requests? Have verified IP helper addresses are on all routers on LAN. Switch above 3550 forwards requests and is GigaStacked to Catalyst 3548.
Thanks in advance.
DTA
1 REPLY
VIP Purple
Re: Issue with Catalyst C3550 forwarding Client DHCP Requests
are you referring to a specific problem you are experiencing ? Which IOS version are you running ? Something might be found in the Bug Toolkit, but you need a CCO login to access it:
Bug Toolkit
http://www.cisco.com/cgi-bin/Support/Bugtool/home.pl
Georg
95
