Webcast-Catalyst9k
Issue with reverse Telnet
I'm using a 2509 to connect to multiple Cisco devices. The problem that I'm having is that as soon as I connect to one of the devices, I am stuck in there and cannot get out using the Ctrl-Shift-6-X combination. What's the trick?
I've used both Hyperterminal and Procomm to rule out the software.
Thanks.
Silver
Re: Issue with reverse Telnet
did you change the escape character ?
Bronze
Show line on the interface you are connecting to the 2509 with. If you are telneting it is a vty interface. This will show you the escape character that is set. When 2509 is used to access routers the escape is usually changed so the normal sequence will work on the router you are reversed telnetd to.
No I haven't changed the escape character. How do I check for that?
Silver
the above posts states how to find it
do a sh line xx
>sh line 66
Tty Typ Tx/Rx A Modem Roty AccO AccI Uses Noise Overruns Int
* 66 VTY - - - - - 167 0 0/0 -
Line 66, Location: "", Type: "XTERM"
Length: 57 lines, Width: 141 columns
Baud rate (TX/RX) is 9600/9600
Status: PSI Enabled, Ready, Active, No Exit Banner, Automore On
Capabilities: none
Modem state: Ready
Group codes: 0
Special Chars: Escape Hold Stop Start Disconnect Activation
^^x none - - none
Timeouts: Idle EXEC Idle Session Modem Answer Session Dispatch
00:15:00 00:15:00 none not set
are you connected via console port and doing reverse telnet connection then?
If yes, Ctrl-Shift-6 x should work with no problem.
Don't forget: Ctrl-Shift-6, release keyboard and then press x.
If you are using telnet as primary access to the 2509 and doing reverse telnet to the device then, simply close the Hyperterminal window and open a new session to connect to a different device.
Milan
Hi , I am consoled in the 2509 then do a reverse Telnet to a 1720 as a test. Once I'm in the 1720, I doa Ctrl-Shift-6 then X, it takes me back to the 2509, but as soon as hit Enter on the 2509, it takes me back to the 1720. Any ideas?
Thanks!
Silver
When you do a cntrl shif t 6 it only suspends your session , if you want to terminate your session type exit on the 1720 or do a cntrl shft 6 x then on the 2509 clear the line you just accessed .
i.e If your session was connected over async line 2 type clear line 2 . a show line will show you what line you are connected on .
Bronze
The disconnect command (disc) is the correct way to close the session after retruning to the 2509. Entering a blank line (return) will resume the last session if it has not been discconected. Show session ( on the 2509) shows the current sessions. Eventually you will want to connect to multiple routers at the same time. When you return to the 2509 you enter the session number of the router you want to connect back to.
271
