Hi Cisco,
In our enviroment, there is Ciscowork2000 and workstation. In between there is a firewall. From the workstation using Java-plug-in and IE, I like to access the Topology map ( other function is works fine ) but it seems to unable to open up. I believe this is more got to do with firewall blocking ports with Topology map.
If this is the case please tell me what port I need to enable in the firwall.
David Ham
