Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
It's seems, Frame-Relay autoinstall don't work.
Dear Sir!
I've such configuration lab scheme:
R1(new)---F/R---R2---TFTPsrv
Then I use such config (there are FRswitch in my network):
A. Configuration-1
hostname R2
interface serial 0
description F/R side
ip address 1.1.1.1 255.255.255.0
encapsulation frame-relay
ip helper-address <TFTPsrv-ip>
frame-relay map ip 1.1.1.2 100 broadcast
interface ethernet 0
description TFTPsrv side
ip address 2.2.2.1 255.255.255.0
When I use such configuration, I see on R1 (new router):
interface s0
no ip address
frame-relay lmi-type cisco
shutdown
Then I'm trying Configuration-1 PLUS ip dhcp option.
B. Configuration-2:
<Configuration-1>
ip dhcp pool 1
host 1.1.1.2 /24
Then I see on R1 (new router):
interface s0
no ip address
shutdown
Then I'm trying Configuration-1 PLUS other ip dhcp option.
C. Configuration-3:
<Configuration-1>
ip dhcp excluded-address 1.1.1.1
ip dhcp pool 1
network 1.1.1.0 /24
interface s0
no ip address
i.e. w/o shutdown option.
What can I say? - it's seems, Frame-Relay autoinstall don't work,
because all other configs (i.e. FRswitch, TFTPsrv ... :) are absolutely correct.
Can you explain me, where I mistaken /or
can you tell me correct configuration
Best regards,
Nick
1 REPLY
Bronze
Re: It's seems, Frame-Relay autoinstall don't work.
Nick,
I have seen Autoinstall work several times over frame relay, but I have always used sub-interfaces to do so.
Your configuration looks good to me. One thing that may be useful to you is to observe whether or not R2 sees DLCI 100 go active after R1 boots up.
BTW, how long do you wait for the autoinstall process to complete? It does take a while, because the first thing that the serial interface of the new router will try is SLARP over HDLC before trying BOOTP over frame relay.
Good Luck,
Mark
108
