ITM 2.0 and CWCS for drop-in modules
I planned to install an ITM 2.0 platform to support a telephony environment.
In the install documents, it seems that ITM is sufficient to support that kind of platform.
I need to install two drop-in modules IPIU 2.0 and IPHDU 2.0. Must I install Common Services 2.2 in addition to ITM 2.0 to support them or is ITM able to support these two drop-in without CWCS installation ?
Thanks for your help.
Patrice
Blue
Re: ITM 2.0 and CWCS for drop-in modules
According to cw-ipiu20-w2k-README.html for the IPIU 2.0 on CCO: "To install IPIU 2.0, ITM 2.0 must be installed on your Windows 2000 system. All hardware and software requirements for IPIU installation match those needed for ITM 2.0 installation".
As for IPHDU 2.0, refer to cw-iphdu20-win-README.html on CCO for installation requirements. It does not need CWCS/VHM to be installed first.
I installed ITM 2.0 and IPIU 2.0 and IPHDU 2.0 without any problem.
85
