Java Plug-in issue for Ciscoworks VMS 2.2
I have Java Plug-in 1.4.1_02 installed in Windows 2000 Advanced Server with SP4 . However , while I use the configuration>Access Rule within Management center for Firewall , it always lead me to install Java(1.3.1) . But the other function seem to work fine with 1.4.1_02 . If somebody can tell me why it happen !! Thks !!
1 REPLY
Blue
Re: Java Plug-in issue for Ciscoworks VMS 2.2
Plug-in 1.4.1_02 is only supported with VMS 2.2 is you have installed Update-1 patch from CCO first: http://www.cisco.com/cgi-bin/tablebuild.pl/vms-3des
Refer to the readme file for more details.
79
