Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
JRM down - problem with software image distribution
I am at my wits end on this. Any suggestions would be greatly appreciated!
(CD1 4th edition, on NT)
Trying software distribution for the first time. I first got an error when I tried to initiate a software distribution job - the error indicated was:
Problem Cause: Device may be used by another Resource Manager
Essentials application.
Recommended Action: Please retry the operation later. If the
problem persists, contact your technical support representative for
assistance.'
Image Upgrade Failed
When I tried to look at the jobs to see if unlocking a job might help I got another error:
JRM display initialization error: error obtaining data from server: JRM is down or is inaccessible
So then I ran self-test and saw the error:
database.pl
FAIL Self Test Fail to query cmf.DbVersion, Error: [Sybase][ODBC Driver][Adaptive Server Anywhere]Unable to
Self Test Fail to query cmf.SYSTABLE, Error: [Sybase][ODBC Driver][Adaptive Server Anywhere]Unable to
Not sure if I have multiple problems here but I haven't been able to find anything on CCO. I have rebooted, re-installed SP6a done log maintenance
Any ideas on where to start to fix this?
TIA
Mark
Blue
Re: JRM down - problem with software image distribution
From the DOS CLI, try doing a 'net stop crmdmgtd' followed by 'net start crmdmgtd' and then repeat the SWIM job again.
Have done that , tried again, same results.
I am wondering if a reload in-place of CD1 or NT would be problematic. I also get Dr Watson user32.dll errors at startup. Or a version upgrade to CD1 5th?
This is a subset of the version information I have now:
CD One Fourth Edition 2.0 6-27-2001 08:41:18 none ENABLED
Software Image Manager 3.3 6-27-2001 08:56:21 ENABLED
Campus Manager 3.1 6-27-2001 09:11:32 none ENABLED
Common Management Foundation 2.0 4-3-2002 10:39:16 1 ENABLED
CMF java2 engine 1.2 6-27-2001 08:41:18 none ENABLED
CiscoView 5.3 6-27-2001 08:41:18 none ENABLED
Database package 4.0 6-27-2001 08:41:18 none ENABLED
CW2000 Process Management package 3.3 6-27-2001 08:41:18 none ENABLED
Resource Manager Essentials 3.3 6-27-2001 08:56:21 none ENABLED
Resource Manager Essentials Incremental Device Support 3.3 6-27-2001 08:56:21 none ENABLED
Essentials VPN Reports 3.3 6-27-2001 08:56:21 none ENABLED
Web Server package 3.2 6-27-2001 08:41:18 none ENABLED
RunTime System package 3.1 4-3-2002 10:39:16 1 ENABLED
Blue
If you can upgrade to 5th Ed, that'll be better.
98
