01-28-2004 12:10 PM - edited 03-02-2019 01:12 PM
I would like to know What command use to set up a port to transport Jumbo/Giant frames? is there any limitation regards type of module (Fast Eth or Gig Eth)? What is the maximum frame size allowed?
Gilson
01-28-2004 05:56 PM
You don't specify whether you're running CatOS or Native. 9K frames are supported by most but not all cards, for native see http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/12_1e/swconfig/sw_int.htm#1041111
01-29-2004 06:48 AM
Thanks - The Switch is runnign CatOS. We are planning to use the jumbo frames between two servers in the same VLAN in the same Gigabit Ethernet blade.
I am reading the document you sent me and looks like we are not going to be able to use the Gigabit blade.
You may consider it solved.
Gilson
