Known issues with ROMMON 5.4(1)
We are upgrading our 4006 routers to CATOS 7.4(3). Our current ROMMON version is 5(4).1. I was wondering if anyone has experienced any issue or difficulties with upgrades under ROMMON version 5(4).1.
Thank you,
J. Holderfield
1 REPLY
Re: Known issues with ROMMON 5.4(1)
You should be fine as 5.4(1) is the minimum required ROMMON.
If you decide to upgrade rommon, the release notes should help
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/relnotes/ol_1983.htm#150924
102
