L3 switch routing question
Hi all,
I have a Catalyst 3550-SMI and I want to use it to perform Layer 3 routing to separate two private networks 192.168.1.x/24 and 192.168.2.x/24.
Router f0/1(192.168.1.1/24)<-> catalyst3550 f0/1(192.168.1.254/24)
catalyst3550 f0/2 (192.168.2.1/24) <-> client (192.168.2.2./24)
I have enabled ip routing so show ip route will display both network in its ports, and enabled L3 switch function. I am able to ping both router ip addr eth0 (192.168.1.1/24) and client pc (192.168.2.2/24) only from this switch.
But the client and the router are not able to ping each other.
I want to use 192.168.1.1 is the only way out from both of networks to the internet. Any helps and suggestions will be greatly appreciated.
Thank you very much.
b.go
1 ACCEPTED SOLUTION
Bronze
Re: L3 switch routing question
Just to check, did you try setting the default gateway of the client to 192.168.2.1? Also, the router (192.168.1.1) should see a route to 192.168.2.0/24 with a next hop of 192.168.1.254.
HTH.
Bronze
HTH.
Hi all, thank you for the advices. Sorry after a week long (sick leave).
I think I forgot to add static route for 192.168.2.x through the same interface as 192.168.1.x. Now it's working properly, thanks a lot.
Best regards,
b.go
I think you made a typo, but you do have 3550 -EMI, not 3550-SMI?
98
