L3Aging cause on a 6500 a load of 100.00% over hours
How is wrong to cause this output on two parallel Backbone Switch?
The entire network works still and no users calling, after a boot was all again well
sh proc cpu
CPU utilization for five seconds: 99.24%
one minute: 100.00%
five minutes: 100.00% . . .. . . . .
34 982835122 405584219 110000 86.64% 87.84% 87.96% -2 L3Aging
Re: L3Aging cause on a 6500 a load of 100.00% over hours
What software version are you running on the Supervisor and the MSFC. Take a look at the following bug
http://www.cisco.com/cgi-bin/bugtool/onebug.pl?bugid=CSCdr10379
Yes, we are currently using a relative old version and Netflow is active.
On the same customer we have already Cat OS 6.3(5) on SUP-1A and IOS 12.1(11) on MSFC running and until now no similar bad effects.
Question: is there something changed in the Software to eliminate the problem?
esw05300> (enable) sh ver
WS-C6506 Software, Version NmpSW: 5.5(3)
NMP S/W compiled on Sep 8 2000, 17:39:10
Yes, this bug has been resolved. If you want to stay in 5.5(x), 5.5(16) which is our latest GD should be good code to run. If you want to upgrade to 6.x, 6.3(9) should be good. Make sure you read the release notes for known issues
Hi, The Customer has Cat OS 6.3(5) and IOS 12.1.11 on the MSFC.
Is there the fix also implemented?
The Customer is very conservative because the system has first to work and has some bad experience with too new releases.
This bug was fixed in 6.1(1). However, 6.3(9) should be the way to go
110
