Community Member
LACP across two switches
Is it possible yet to etherchannel (using LACP) from a server using Broadcom NICs (with the latest drivers and software) to two Cisco switches?
I heard that etherchannel has evolved but not sure to what extent. Thanks.
VIP Purple
Re: LACP across two switches
I assume you are referring to multichassis LACP Etherchannels, that is, each NIC going into a different switch, and both links forming a channel ?
GP
Community Member
That is correct. Is it possible yet? Thanks.
VIP Purple
TMBK, the only way to configure an Etherchannel (wether PAgP or LACP doesn´t matter) is across a stack, because apparently that is the only way the channel group interface knows that it belongs to ports on different physical switches...
I will ask around if that has changed and let you know.
GP
Community Member
Does that mean that it is possible to configure an etherchannel between a 7206 router and two catalyst 3550 if both switches are linked together with a gigastack gbic ?
171
