LAN - 1605 - LAN - Inetnet
I have a 1605R plugged in with 2 ehternet interface. I am trying to do NAT between the interfance. Eth0(10.0.0.1) is inside and eth1 is outside (192.168.1.5). I am able to ping devices on the 192.168.1.x Net but not to internet. here is the config
ip subnet-zero
ip dhcp excluded-address 10.0.0.1
ip dhcp pool 1
network 10.0.0.0 255.255.255.0
default-router 10.0.0.1
domain-name abc.com
dns-server 192.168.1.1
interface Ethernet0
ip address 10.0.0.1 255.255.255.0
ip nat inside
interface Ethernet1
ip address 192.168.1.5 255.255.255.0
ip nat outside
ip nat inside source list 101 interface Ethernet1 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Ethernet1
ip http server
access-list 101 permit ip 10.0.0.0 0.0.0.31 any
line con 0
password xxxx
line vty 0 4
password xxxx
login
end
Re: LAN - 1605 - LAN - Inetnet
Can you confirm whether you are doing one more Natting out there in the second LAN segment ?
Also can you post out a sample fig representing your topology like how the equipments are connected ?
That will def help out to suggest more n more possible ways out ther in getting the things better and simpler..
regds
10.0.0.x netowrk gets natted to 192.168.1.5 which gets natted before going to internet. However it does not gets natted while hitting other networks with in the same company 192.168.x.0.
thanks
Can you add remove the static route which is already there in place and add a new router like this ??
Assuming 192.168.1.2 as the ethernet ip of your second router..change accordingly as per your ip adress configured under the ethernet interface..
no ip route 0.0.0.0 0.0.0.0 Ethernet1
ip route 0.0.0.0 0.0.0.0 Ethernet1 192.168.1.2
Pls check after adding this and also post your other routers config here so that it will be easy to troubleshoot..
regds
159
