lan extender problem
I have a cisco lan extender 1001, and am unable to ping the interface. I have been experamenting in every way I can think of and the latest config for the router is as follows Current configuration:
version 11.0
service udp-small-servers
service tcp-small-servers
hostname Router
interface Ethernet0
no ip address
shutdown
interface Serial0
no ip address
shutdown
no fair-queue
interface Serial1
ip address 201.100.111.1 255.255.255.0
encapsulation ppp
clockrate 56000
interface Lex1
ip address 201.100.11.1 255.255.255.0
no fair-queue
lex burned-in-address 0000.0c33.6636
line con 0
line aux 0
transport input all
line vty 0 4
login
end
the status of the interfaces are as follows
Serial1 is up, line protocol is up
Hardware is HD64570
Internet address is 201.100.111.1 255.255.255.0
MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec, rely 255/255, load 1/255
Encapsulation PPP, loopback not set, keepalive set (10 sec)
LCP Open
Listen: cdp
Open: lex
Last input 0:00:00, output 0:00:00, output hang never
Input queue: 0/75/0 (size/max/drops); Total output drops: 0
Output queue: 0/64/0 (size/threshold/drops)
Conversations 0/1 (active/max active)
Reserved Conversations 0/0 (allocated/max allocated)
5 minute input rate 0 bits/sec, 1 packets/sec
2919 packets input, 99315 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
2488 packets output, 40052 bytes, 0 underruns
0 output errors, 0 collisions, 4 interface resets, 0 restarts
0 carrier transitions
DCD=up DSR=up DTR=up RTS=up CTS=up
and the lex is
Lex1 is up, line protocol is up
Hardware is Lan Extender, address is 0000.0c33.6636 (bia 0000.0c33.6636)
Internet address is 201.100.11.1 255.255.255.0
Encapsulation ARPA, loopback not set, keepalive set (10 sec)
ARP type: ARPA, ARP Timeout 4:00:00
Bound to Serial1
Last input 0:00:05, output never, output hang never
Output queue 0/40, 0 drops; input queue 0/75, 0 drops
425 packets input, 57770 bytes, 0 no buffer
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets, 0 restarts
yet I am not able to ping the port even with a ip address in the serial 1 configured or not configured. I did a debug on the ppp conection and it says unsported or unnegotiated protocall. show cdp neighbors does not see the router either, and I am still unable to get thru the extender. can anyone help.
1 REPLY
Silver
Re: lan extender problem
This sounds like an issue with the Lan Extender itself. Look over this link http://www.cisco.com/univercd/cc/td/doc/product/access/acs_fix/1000ig/1000ig/65084.htm#xtocid2925816 and if it does not solve the issue then you may need to get with the TAC for this
218
