03-08-2004 04:30 AM - edited 03-02-2019 02:06 PM
Anyone on this forum had configured catalyst 4003 with 2 gigabit ports in L3 module? I wanted to use these 2 gigabit ports as my backbone connecting to catalyst 2950 gigabit ports. Unfornately, i can't configured correctly. I can see the peer switch (cat. 2950) from the router side through cdp but not on the switch side of the cat. 4003 that is why i can't pinged the access switch 2950 ip. Also, i can see the cat. 4003 from cdp neighbors of cat. 2950 but from there i can't pinged the cat.4003 switch. Anyone, could help how to activate it correctly so i can upgrade and use the gigabit port as my backbone line?
Cheers,
Randy
03-08-2004 05:30 AM
How about some of your configurations and CDP neighbor output (with details). Difficult to debug what we can't see at all.
03-14-2004 05:14 PM
I issue command sh cdp neigbors detail on the L3 of cat. 4003 and it shows the IP address of the cat. 2950 (e.g 10.10.2.1), the names and others details on it. But when i'm in the switch OS of catalyst 4003 and issue command sh cdp neighbors detail, pls. see the captured sh cdp. I can't see the peer ip address of cat. 2950 (10.10.2.1).
cat4003 (enable) sh cdp neighbors detail
Port (Our Port): 2/1
Device-ID: Cat4003Router
Device Addresses:
IP Address: 127.0.0.3
Holdtime: 165 sec
Capabilities: ROUTER
Version:
IOS (tm) L3 Switch/Router Software (CAT4232-IN-M), Version 12.0(14)W5(20) REL
EASE SOFTWARE
Copyright (c) 1986-2001 by cisco Systems, Inc.
Compiled Thu 01-Mar-01 18:18 by integ
Platform: cisco Cat4232L3
Port-ID (Port on Neighbors's Device): GigabitEthernet3
____________________________________________________
Device Addresses:
IP Address: 192.168.34.3
Holdtime: 165 sec
Version:
EASE SOFTWARE
Port-ID (Port on Neighbors's Device): Port-channel1.1
_____________________________________________________
Port (Our Port): 2/2
Device Addresses:
Holdtime: 165 sec
Version:
EASE SOFTWARE
Port-ID (Port on Neighbors's Device): GigabitEthernet4
Port (Our Port): 2/3
Device-ID: wmnl139
Device Addresses:
IP Address: 192.168.24.1
Holdtime: 172 sec
Version:
IOS (tm) C2600 Software (C2600-IS-M), Version 12.0(4), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-1999 by cisco Systems, Inc.
Compiled Wed 14-Apr-99 21:19 by ccai
Platform: cisco 2610
Port-ID (Port on Neighbors's Device): Ethernet0/0
Port (Our Port): 2/27
Device-ID: Router_3640
Device Addresses:
IP Address: 192.168.26.1
Holdtime: 131 sec
Version:
IOS (tm) 3600 Software (C3640-IS-M), Version 12.0(7)XK2, EARLY DEPLOYMENT RELE
ASE SOFTWARE (fc1)
TAC:Home:SW:IOS:Specials for info
Copyright (c) 1986-2000 by cisco Systems, Inc.
Compiled Tue 31-Oct-00 22:14 by kpma
Platform: cisco 3640
Port-ID (Port on Neighbors's Device): FastEthernet1/0
From the cat. 2950, i issue command sh cdp neighbors detail and it shows me the name of the catalyst 4003, the ip address is 127.0.0.3 trunk connected to gigabit 2 (outgoing) gigabit 0/2 (this is gigabit of catalyst 2950). Why i can't see the IP address of catalyst here?
My config on catalyst 4003
set the 2 gigabit port 2/1-2 to trunk on WS-X4232-L3 module
set trunk 2/1-2 desirable dot1q
and create port-channel 1 for 2/1-2
What other configuration that i need to add here?
My gigabit configuration on cat. 2950.
I created port-channel 1
port-channel 1
switchport mode trunk
switchport trunk allowed vlan 3
On Gigabit port, here is my config.
Gigabit ethernet 0/2
channel-group 1 mode desirable
no shut!
Hope you can help me on this..
03-15-2004 06:13 AM
Ok, first, I believe the 4003 with a L3 services engine is similar to a Cat 6500 running in Hybrid mode. That would mean that the GBIC ports are actually on the CatOS side of the unit, not the IOS side. Have you tried issuing a CDP neighbor from the 4003 CatOS/L2 side? Is this how the 4003 with L3 engine works?
Now, I'm getting very confused about your IP Addressing... What are the IP addresses and subnet masks of the various players involved here. Why am I seeing IP addresses that are obviously in different subnet ranges? So far I have seen
192.168.24.X, 192.168.26.X, 192.168.34.X (could be in same subnet possibly? Probably not though?)
10.10.2.X
127.0.0.3? (Is this an actual assigned IP to a device? 127.0.0.X is reserved for loopback addresses)
If they are on different subnets, that would make an easy explanation why they can't ping eachother. But as far as CDP, is there a L2 side of the 4003? Can you do a CDP from there?
More importantly, what are the IP addresses/subnets of the various devices?
03-16-2004 02:05 AM
Hi Craig,
Actually, i had configured diff. subnets/24 on catalyst 4003. The 127.0.0.3 is actually the automatic assigned by the system CatOS. That's what i saw when i issue CDP neighbor details on the catOS. I can't see the peer switch (cat. 2950) ip address on the catOS of 4003 but on the IOS side I can see it, weird? Is there a configuration that i should do on the L2 of cat4003? or also have reconfigure the peer switch (cat.2950)?
Here's the ip address configured on my cat.4003
ip add of sc0 interface is on 192.168.15.x/24
Vlan 1 ip 192.168.15.x/24 - this subnet is where the server connected and some users. also this subnet where i plan to connect the cat2950.
Vlan 2 ip 192.168.16.x/24 - also for users here.
Vlan 3 ip 192.168.24.x/24 - subnet where our branches connected
Vlan 4 ip 192.168.26.x/24 - also for branches
Vlan 5 ip 192.168.34.x/24 - this subnet for our users here in the ofc. Also plan to install cat2950.
There's another vlan 77 that i set to native (no users/ports configured)
On L3 of cat4003.
It was configured to a port-channel
configured sub port-channel 1.15 for Vlan 1
configured sub port-channel 1.16 for Vlan 2
configured sub port-channel 1.24 for Vlan 3
configured sub port-channel 1.26 for Vlan 4
configured sub port-channel 1.34 for Vlan 5
RIP is my configured Routing Protocol
Configured Gigabit 3(g3) for channel-group 1. G3 is handling the interVlan routing.
I'm really having trouble configuring trunks on cat4003. I can't make it to work ;( grrrrrr...
What do you thinks seems to be the problem?
Cheers,
Randy
03-17-2004 08:54 AM
Hmm... I'm still a bit confused, this appears to operate quite a bit differently than what I'm used to on the catalysts we have here or your definitely doing something wrong.. Can you get the config's on the various components (4003, both catos and ios side) and 2950 and put them up here? I can probably figure out what your talking about from there.
03-18-2004 04:59 PM
Hi Craig,
Here's my CatOS 4003 config.
begin
# ***** NON-DEFAULT CONFIGURATION *****
#time: Sat Mar 6 2004, 08:24:51
#version 7.1(2)
#system web interface version(s)
#test
#frame distribution method
set port channel all distribution mac both
#vtp
set vtp domain HQ
set vlan 1 name default type ethernet mtu 1500 said 100001 state active
set vlan 2 name HRDBldg type ethernet mtu 1500 said 100002 state active
set vlan 3 name MainBldg. type ethernet mtu 1500 said 100003 state active
set vlan 4 name Branch01 type ethernet mtu 1500 said 100004 state active
set vlan 5 name Branch02 type ethernet mtu 1500 said 10005 state active
set vlan 77 name dummy type ethernet mtu 1500 said 100077 state active
set vlan 1002 name fddi-default type fddi mtu 1500 said 101002 state active
set vlan 1004 name fddinet-default type fddinet mtu 1500 said 101004 state active stp ieee
set vlan 1005 name trnet-default type trbrf mtu 1500 said 101005 state active stp ibm
set vlan 1003 name token-ring-default type trcrf mtu 1500 said 101003 state active mode srb aremaxhop 7 stemaxhop 7 backupcrf off
#ip
set interface sc0 1 192.168.15.252/255.255.255.0 192.168.15.255
set interface sl0 down
set interface me1 down
set ip route 0.0.0.0/0.0.0.0 192.168.15.3
#spantree
#vlan
#syslog
set logging level cops 2 default
#set boot command
set boot config-register 0x2
set boot system flash bootflash:cat4000-k8.7-1-2.bin
#port channel
set port channel 2/1-4 127
#multicast filter
set igmp filter disable
#module 1 : 0-port Switching Supervisor
#module 2 : 34-port Router Switch Card
set vlan 1 2/3-6,2/9-18
set vlan 2 2/19-26,2/34
set vlan 3 2/27-33
set vlan 4 2/7
set vlan 5 2/8
set vlan 77 2/1-2
set trunk 2/1 nonegotiate dot1q 1-1005
set trunk 2/2 nonegotiate dot1q 1-1005
set spantree portfast 2/3,2/14,2/19,2/22,2/25,2/29 disable
set spantree portfast 2/4-13,2/15-18,2/20-21,2/23-24,2/26,2/28,2/30-34 enable
set spantree portinstancecost 2/3 cost 19999 mst
set spantree portinstancecost 2/4 cost 19999 mst
set spantree portinstancecost 2/5 cost 19999 mst
set spantree portinstancecost 2/6 cost 19999 mst
set spantree portinstancecost 2/7 cost 19999 mst
set spantree portinstancecost 2/8 cost 19999 mst
set spantree portinstancecost 2/9 cost 19999 mst
set spantree portinstancecost 2/10 cost 19999 mst
set spantree portinstancecost 2/11 cost 19999 mst
set spantree portinstancecost 2/12 cost 19999 mst
set spantree portinstancecost 2/13 cost 19999 mst
set spantree portinstancecost 2/14 cost 19999 mst
set spantree portinstancecost 2/15 cost 19999 mst
set spantree portinstancecost 2/16 cost 19999 mst
set spantree portinstancecost 2/17 cost 19999 mst
set spantree portinstancecost 2/18 cost 19999 mst
set spantree portinstancecost 2/19 cost 19999 mst
set spantree portinstancecost 2/20 cost 19999 mst
set spantree portinstancecost 2/21 cost 19999 mst
set spantree portinstancecost 2/22 cost 19999 mst
set spantree portinstancecost 2/23 cost 19999 mst
set spantree portinstancecost 2/24 cost 19999 mst
set spantree portinstancecost 2/25 cost 19999 mst
set spantree portinstancecost 2/26 cost 19999 mst
set spantree portinstancecost 2/27 cost 19999 mst
set spantree portinstancecost 2/28 cost 19999 mst
set spantree portinstancecost 2/29 cost 19999 mst
set spantree portinstancecost 2/30 cost 19999 mst
set spantree portinstancecost 2/31 cost 19999 mst
set spantree portinstancecost 2/32 cost 19999 mst
set spantree portinstancecost 2/33 cost 19999 mst
set spantree portinstancecost 2/34 cost 19999 mst
#module 3 empty
end
03-18-2004 05:03 PM
Hi Craig,
My Cat4003 IOS
version 12.0
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname Cat4003Router
ip subnet-zero
interface Port-channel1
no ip address
no ip directed-broadcast
hold-queue 300 in
interface Port-channel1.1
encapsulation dot1Q 1
ip address 192.168.15.3 255.255.255.0
ip helper-address 192.168.15.10
ip helper-address 192.168.15.8
ip helper-address 192.168.15.7
ip helper-address 192.168.15.13
ip helper-address 192.168.15.14
ip helper-address 192.168.15.16
ip helper-address 192.168.15.20
ip helper-address 192.168.15.6
ip helper-address 192.168.16.8
ip helper-address 192.168.34.8
no ip redirects
interface Port-channel1.2
encapsulation dot1Q 2
ip address 192.168.16.3 255.255.255.0
no ip redirects
interface Port-channel1.3
ip address 192.168.24.3 255.255.255.0
no ip redirects
interface Port-channel1.4
ip address 192.168.26.3 255.255.255.0
no ip redirects
interface Port-channel1.5
encapsulation dot1Q 3
ip address 192.168.34.3 255.255.255.0
no ip redirects
interface Port-channel1.77
encapsulation dot1Q 77 native
interface FastEthernet1
no ip address
shutdown
interface GigabitEthernet1
no ip address
no shutdown
interface GigabitEthernet2
no ip address
no shutdown
interface GigabitEthernet3
no ip address
no negotiation auto
channel-group 1
interface GigabitEthernet4
no ip address
no negotiation auto
router rip
passive-interface FastEthernet1
network 192.168.15.0
network 192.168.16.0
network 192.168.24.0
network 192.168.26.0
network 192.168.34.0
ip classless
line con 0
transport input none
line aux 0
line vty 0 4
login
password cisco
end
03-18-2004 05:10 PM
My 2950 config.
version 12.1
no service pad
hostname Cat2950HRDSW
enable secret xxxxxx
ip subnet-zero
vtp domain HQ
vtp mode transparent
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
vlan 2
switchport trunk allowed vlan 2
interface FastEthernet0/1
switchport access vlan 2
switchport mode access
duplex half
speed 100
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
duplex half
speed 100
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
no ip address
no ip route-cache
shutdown
interface Vlan2
ip address 192.168.16.252 255.255.255.0
no ip route-cache
ip http server
line con 0
line vty 0 2
password c1sc0
login
line vty 3 4
login
line vty 5 15
login
end
03-18-2004 05:11 PM
My another 2950 switch.
version 12.1
no service pad
hostname Cat2950MainSW
enable secret xxxxx
ip subnet-zero
vtp domain HQ
vlan 3
switchport access vlan 3
channel-group 1 mode on
interface Vlan1
no ip address
no ip route-cache
shutdown
interface Vlan3
ip address 192.168.34.252 255.255.255.0
no ip route-cache
ip http server
line con 0
line vty 0 2
password xxx
login
line vty 3 4
login
line vty 5 15
login
end
03-22-2004 07:26 AM
I guess I'm a bit confused still... It doesn't look as if any of the gigabit ports that are in the l3 engine show up on the l2 side, on the cat6500 MSFC's you only see the "VLAN" interfaces, not the "Gigabit" interfaces.
Even with these, I'm still not completely sure where your 2950's are plugging into on the 4003, I'm assuming that one of them is going to Gigabit3 on the L3 engine for your 4003. Is that correct?
First, why are you using port-channels everywhere? Are you planning on moving to greater-than 1Gb links to the different switches? port-channel's (or etherchannel) is used to combine two or more links together to form one link. Absolutely everything about each port in the channel needs to be the same at both ends for this to work and can cause some problems in diagnosing connectivity problems. If your not doing this, or planning to do it in the very near future, I would stop doing this. In order to do so, you would have to change your "Portchannel1.1's" and such on your 4003 to be "Gigabit3.1" and moving the config's to there. I would recommend this.
Also, in order to help you keep things straight in your head, set your subinterface # to be equal to your vlan number. So, if you're using vlan 4 on a subinterface, make the sub-interface # "portchannel1.4" or "gigabit3.4" or whatever.
I did notice that you have things quite confused in your Portchannels on your L3 engine. Note below from your configs that channel 1.2, 1.3, 1.4 are all on vlan 2 (dot1q 2), not to mention they're all on different subnets. You should have 1 VLAN per sub-interface and have each vlan its own subnet.
Now, on each switch, you have it trunked to the switch, but you're only allowing 1 VLAN to be on that trunk, a bit odd use of trunking. If this is really what you want to do, why not just on each side of the link, put the "uplink" port into the VLAN you want the switch to be on, then put all the ports in that switch onto that VLAN. You avoid the potential problems associated with trunking.
If you want to have multiple VLAN's go to each switch, that's fine too, but then I would take advantage of it and designate 1 VLAN to be your "management VLAN". Then, allow the management VLAN to go to every switch (ie: put it in its vlan database) and put the management address for each switch into this VLAN. The devices that connect into the switch could be on another VLAN, but all the switches would be in a single subnet for management. Personally I'd make the management VLAN the "native" VLAN on your switches, and there are some arguments to use VLAN 1 for this (as well as some against). I noticed on your 2950's that you don't have VLAN77 on them even though it is the native VLAN on the 4003, which I don't like.
Either approach will work, but try and simplify your configurations a bit. Get everything working without your etherchannels first, then work at putting them back in if desired. I think you're trying to accomplish too much all at one time. Go back to the basics and get it working, then implement the features you want one step at a time... Spend time documenting what your doing in your configurations (ie: in the interfaces configuration put a "description" in saying what its connecting too). You will be happy for doing so in the long run. For one, asking people on this forum gets to be very confusing for us not having this stuff documented...
Good luck!
