LAN Management Solution & VPN/Security Management Solution
We are using now LMS 1.1 ( Only RME,CiscoView). because we are having Problems with the Performance of our Server we thought of Upgrading to higher version, at the same time we have PIX and VPN Concetrators . My question is , is it better to Upgrade to LMS 2.1 or change to change to VPN/Security Management Solution .
Any recomendations .
Blue
Re: LAN Management Solution & VPN/Security Management Solution
It depends as to what kind of specific management are you looking to do with your VPN Concentrators/PIX ?
actually , we would like to manage and configure the VPN Connectors and PIX's.
105
