Lan redundancy
Hi All,
From my 2821 router I wish to use both onboard gig ports to my two stacked 3750 switches. since I cannot run etherchannel between the switch and the router, i was wondering what the best answer would be.
TIA,
R
Silver
Re: Lan redundancy
You should be able to run EtherChannel on your router, unless it is not supported by that platform.
Thanks.
Re: Lan redundancy
its not supported by the onboard ethernet ports.
Silver
Re: Lan redundancy
You may be able to bridge the two ports on the router and turn on STP but this will not use both ports simultaneously.
Thanks.
Re: Lan redundancy
if it is just for redundancy you can use:
- pbr
-hsrp or glbp
-routing dynamic
Regards.
113
