LAN segemnts
Four LAN segments: Three with 50 hosts each, and the fourth segment having 250 hosts. I want to connect these 4 segments with a switch, but I am unsure of how the address tables are compiled. Are there restrictions on the number of address that can be assigned to any single port? Would a 1900 or 2950 be suitable? Should be 10/100 and capable of full duplex. VLANs not used at this time.
1 REPLY
Re: LAN segemnts
The tables are bult up via 802.1d, this link will give you the basic's of bridging.
http://www.cisco.com/univercd/cc/td/doc/cisintwk/ito_doc/bridging.htm
as for the No of MAC address the 2950 can handle is 8,000 so yes you would not have an issue, however i would suggest that you look at creating VLAN's to minimise your collision/Broadcast domain as this can have a major impact on network performance.
108
