LAN to LAN Routing / Connectivity
Does Cisco have a simple router that is suitable for connecting two LANs via twisted pair (ethernet) or fiber optic cable?
Thanks for your assistance.
Bronze
Re: LAN to LAN Routing / Connectivity
The 1710 router is a low end router with 2 RJ45 ethernet ports.
I appreciate your suggestion. Will this router work without a cable/DSL connection? The configuration requires a 10/100 hub (one per LAN) on either side of the router.
As mentioned the 1710 is a low end router that will do the job. You need ADSL/T1 etc only when connecting to an ISP or a remote office but as i understand it all you need to to connect two segments then the 1700 series should do it
thanks
http://www.cisco.com/en/US/partner/products/hw/routers/ps221/index.html
Bronze
The 831 also has 2 ethernet ports, one of which is 10Mb however.
http://www.cisco.com/en/US/customer/products/hw/routers/ps380/products_data_sheet09186a008010e5c5.html
hth
Herbert
Thank you. I will go ahead and order one.
Thanks again
110
