Layer 2 and Layer 3 Flows on Catalyst 4006 and 6509
Can anyone advise on the following scenario....
4006 Supervisor 3 - multiple vlans (layer 3 switching) scenario
1. If the supervisor 3 fails on the 4006, how long will the Layer 2 and Layer 3 flows exist on the box. (I presume Layer 3 flows will cease to exist)
2. How long will each user have layer 2 access to the LAN (1 big domain / VLAN).
The way I understand it is that Layer 2 flows will exists as long as the CAM is active. I am correct in saying this
6509 - I supervisor (no redundancy and layer 3 switching) mutliple vlan scenario
1. If a sup fails on the 6509, how long will layer 2 and layer 3 flows exist.
Any input is greatly appreciated
Rob
  • Other Network Infrastructure Subjects
Re: Layer 2 and Layer 3 Flows on Catalyst 4006 and 6509
I think,there might be many kinds of failure.If the DRAM or stuffs responsible for storing dynamic information corrupts,anything will be lost.
Thanks for your reply. I understand about CAM, aging etc. I wanted to make sure that a SUP, when it resets or fails etc, does not reset the backplane on the switch causing current L2 flow loss.
I will be testing all scenarios. I will be implementing dual sup's on the 6509, so the issue is not a big one. On the 4006, 1 sup only. I have considred the 4507, but due to its age on the market, it is high risk.
Cheers
Rob
If the entire Supervisor fails, the entire operation of the switch fails if you do not have a redundant Supervisor/Switch. However, in a CAT6509 running hybrid OS, if the Layer 3 card(MSFC) fails, Layer 2 continues to operate(within the VLAN). The default MLS aging time is 256 seconds
89
