Webcast-Catalyst9k
Layer 2 Problem & Bus Error
Hi All,
I am having problems getting multi-frame established... I have a 1603R and am ultimately trying to make a DoV connection - but I'll settle for a data one as well. Layer 2 comes up and then goes down almost immediately - then when it dials I get a bus error? I assume because the frame is not established?
If I try a std data call I get the same problem. Have tried setting setting tei to neg on first call to no avail - bus error on dial as well. Called Telstra (telco) and they say it is setup as point to multi-point. Others have tried my config and say it is fine. Any ideas what to try next?
Details below...
droopa#show isdn status
Global ISDN Switchtype = basic-net3
ISDN BRI0 interface
dsl 0, interface ISDN Switchtype = basic-net3
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 104, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
I_Queue_Len 0, UI_Queue_Len 0
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0x80000003
Number of L2 Discards = 0, L2 Session ID = 6
0:02:51: ISDN BR0: L1 is IF_ACTIVE
00:02:51: ISDN BR0 EVENT: isdn_sw_cstate: State = 4, Old State = 4
00:02:51: ISDN BR0: Incoming call id = 0x0003, dsl 0
00:02:51: ISDN BR0: Shutting down ME
00:02:51: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BRI0, TEI 84 changed to down
00:02:51: ISDN BR0: Shutting down ISDN Layer 3
00:02:51: ISDN BR0: TX -> IDREQ ri=1463 ai=127
00:02:51: ISDN BR0: RX <- IDASSN ri=1463 ai=85
00:02:51: ISDN BR0: TX -> SABMEp c/r=0 sapi=0 tei=85
00:02:51: ISDN BR0: RX <- UAf c/r=0 sapi=0 tei=85
00:02:51: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0, TEI 85 changed to up
00:02:51: L3: L3_GetUser_NLCB returned NULL, message ignored cid 0x0 cr 0x0 ev 0
x203 ces 1 dsl 0
00:03:01: ISDN BR0: TX -> RRp sapi=0 tei=85 nr=0
00:03:01: ISDN BR0: RX <- RRf sapi=0 tei=85 nr=0
00:03:06: ISDN BR0: RX <- DISCp c/r=1 sapi=0 tei=85
00:03:06: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0, TEI 85 changed to down
00:03:06: ISDN BR0: TX -> UAf c/r=1 sapi=0 tei=85
00:26:33: BR0 DDR: rotor dialout [priority]
00:26:33: BR0 DDR: Dialing cause ip (s=192.168.0.2, d=172.16.20.53)
00:26:33: BR0 DDR: Attempting to dial 0243375600
00:26:33: ISDN BR0: Outgoing call id = 0x8001, dsl 0
00:26:33: ISDN BR0: Event: Call to 0243375600 at 64 Kb/s
00:26:33: ISDN BR0: process_bri_call(): call id 0x8001, called_number 0243375600
, speed 64, call type DATA
*** BUS ERROR ***
access address = 0xffffffff
program counter = 0x240ab60
status register = 0x2700
vbr at time of exception = 0x4000000
special status word = 0x006d
faulted cycle was a byte read
Using 2729 out of 7506 bytes!
version 12.2
no service pad
service password-encryption
! ISP 56K Phone Number 0243375608
! ISP 64K Phone Number 0243375609
! DNS 1 203.24.133.1
! DNS 2 203.24.133.2
hostname droopa
enable secret xxxxxxx
enable password yyyyyy
username user password pass
clock timezone aest 10
ip subnet-zero
no ip domain-lookup
ip name-server 203.24.133.1
ip name-server 203.24.133.2
! basic-net3 is the correct ISDN switch type for use in Australia
! Cisco Fast Step includes the incorrect type.
isdn switch-type basic-net3
! Configure internal Ethernet interface
! Set IP and configure NAT
interface Ethernet0
description Private LAN Interface
ip address 192.168.0.1 255.255.255.0
ip nat inside
! Configure BRI interface
interface BRI0
description ISDN WAN Interface
no ip address
!ip nat outside -- m again
encapsulation ppp
dialer pool-member 1
no cdp enable
! Configure Dialer1
interface Dialer1
description Connect to ECN Internet
ip address negotiated
ip nat outside
encapsulation ppp
no ip split-horizon
dialer pool 1
dialer in-band
dialer idle-timeout 2147483
dialer string 0243375609 class DOV
dialer hold-queue 25
dialer load-threshold 10
dialer-group 4
no cdp enable
!ppp authentication pap callin
ppp authentication chap
ppp chap hostname narara
ppp chap password 7 045F110B5E711519
ppp pap sent-username user password pass
ppp multilink
! Added on M
dialer-list 4 protocol appletalk deny
dialer-list 4 protocol ipx deny
dialer-list 4 protocol netbios deny
dialer-list 4 protocol ip permit
! Enable NAT for the Dialer 1 interface
ip nat inside source list 1 interface Dialer1 overload
! To enable passthrough for incoming IKE VPN traffic
!ip nat inside source static esp 192.168.0.1 interface Dialer1
no ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
!Enable DoV - and set speed to 56k (if required)
map-class dialer DOV
dialer voice-call
dialer isdn speed 56 spc
access-list 1 permit 192.168.0.0 0.0.0.255
access-list 5 permit 192.168.0.0 0.0.0.255
dialer-list 1 protocol ip permit
! Set console and telnet access + password
line con 0
login
stopbits 1
line vty 0 4
access-class 5 in
exec-timeout 0 0
password pass
login
no rcapi server
end
System Bootstrap, Version 12.0(3)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1999 by cisco Systems, Inc.
C1600 platform with 16384 Kbytes of main memory
program load complete, entry point: 0x4020060, size: 0x165eac
%SYS-4-CONFIG_NEWER: Configuration from version 12.2 may not be correctly unders
tood
%SYS-6-BOOT_MESSAGES: Messages above this line are from the boot loader.
program load complete, entry point: 0x2005000, size: 0x31dd08
Self decompressing the image : ####################### [OK]
IOS (tm) 1600 Software (C1600-Y-M), Version 12.2(12a), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Tue 24-Sep-02 05:06 by pwade
Image text-base: 0x02005000, data-base: 0x026602A4
cisco 1603 (68360) processor (revision C) with 12288K/4096K bytes of memory.
Processor board ID 16315448, with hardware revision 00000002
Bridging software.
X.25 software, Version 3.0.0.
Basic Rate ISDN software, Version 1.1.
1 Ethernet/IEEE 802.3 interface(s)
1 ISDN Basic Rate interface(s)
System/IO memory with parity disabled
8192K bytes of DRAM onboard 8192K bytes of DRAM on SIMM
System running from RAM
7K bytes of non-volatile configuration memory.
4096K bytes of processor board PCMCIA flash (Read/Write)
1 ACCEPTED SOLUTION
Re: Layer 2 Problem & Bus Error
My mistake..its not 12.0.3.T..Anyway CSCin10546 is the perfact match for that crash. Pl. view that in bug toolkit and upgrade the 1600 with the one of the resolved image to solve the problem.
Here is the url which has a sample config for DOV call.
http://www.cisco.com/warp/public/793/access_dial/8.html
I would say 12.0.3.T is bit old ios so pl. try to go near the latest ios based on the memory requirement. OR Pl. post the "sh stack" to know what process is causing the crash.
131
