Layer 3 switches
How i can check a specif siwtch is of Layer 3 or layer 2 without considering model. How i can check that whether it has Layer 3 functionalities or not while buying a switch at shop
Silver
Re: Layer 3 switches
The very basic difference is that you can configure routing on a Layer 3 Switch,which is not in Layer 2.
Functions like RIP,IP accesslists etc are configurable in Layer 3 switch.
JD
96
