learn and lock pb
hi,
on a catalyst 3100,
in order to block each mac @ that not belong to known machines, I enabled the "learn and lock" option, I was connected on the switch by telnet. I lost the connection. now, it's like each port is lock, and no machine can connect to the switch. after a reboot, I tried a machine with a mac adress not "learned" by the switch but nothing to do. all the ports are locked. I can do nothing.
it's like the switch is "learning" all the time. What can i do ?
danke schöne
1 REPLY
Re: learn and lock pb
The only problems I have seen with the learn and lock feature is related to DHCP. If you are obtaining your IP address through DHCP, try assigning it statically to see if that makes a difference.
220
