Webcast-Catalyst9k
Leased-lines between multiple BRI and one E1 PRI possible with Cisco?
The Teleco provider provides a PRI port, at which several BRI leased lines end. One E1 channel connects to one BRI leased line. Can I use a 1CE1B (E1 PRI) card in a 3640 router for this to send data traffic over different channel groups? Or are there other solutions?
1 REPLY
Anonymous
N/A
Re: Leased-lines between multiple BRI and one E1 PRI possible wi
Yes, you can. This is an E1 point-to-multipoint scheme.
108
