LED Status
How can I request the status of the LED (green or yellow) for the ports at the front of catalyst 2950-48 from remote.
I dont found any information in the show commands.
I have 2 Switches in parallel for redundancy, so I like to know from remote (telnet) which Switch is working and which is standby.
Thanks.
Markus
1 REPLY
Re: LED Status
You cannot find the status of LED from a sh command. The common LED states are explained here.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat2950/12114az/2950hig/hgovrev.htm#55402
However if you have web interface through Visual switch manager, you can have a graphical interface to the switch using a internet browser
http://www.cisco.com/warp/public/473/59.html
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat2950/12119ea1/2950scg/swcms.htm#999123
103
