limitation in stacking switches
In our campus network there are many stacked switches. I observed every where maximum 5 or 6 switches in stack.
When I tried to add two more switches to the stack, entire stack is down.
Based on existing diagrams I came to one conclusion that stacking will not support more than 6 switches. Is it true?
skrao
Re: limitation in stacking switches
Not mentioned any switch type. Assuming it should be gigastack and there are limitations in number of switches in stack (MAX to 9). For more details check out the below URL
http://www.cisco.com/en/US/products/hw/switches/ps607/products_tech_note09186a00800a2cac.shtml
Hope that helps.
Hi SK,
Which switches you are having in your STACK conenction as 3750 switch stack can have up to nine stack members.
Ankur
Some switches are 2950, some switches are 3548. some of them are running 12.0, some of them are running 12.1
skrao
102
