Line Console X where X is greater than 0
ramez.dous
Is there is such command?
Line console 4 or Line console 5?
Thank you!
Since your device has only one console port, you should use line console 0. But you can use line console 1 or 2 or 3.... if you are using a terminal server option.
Please rate the comment if it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
5 Replies 5
ramez.dous
Did I write the question in the wrong section?
So to make it clear
1- Cisco devices have only 1 console port, so the only option is "Line Console 0"
2- Line Console 1 or 2 or 3 ,... exists only in terminal servers as they connect to many devices through devices console port.
am i right?
Yeap you are correct.
There are terminal server devices to connect with other devices using console ports.
Thank you : )
