Line going up and down
I am trying to hookup a T1 line to a AS5300 router but the T1 controller and serial interfaces go up and then come back down after a few seconds. During the time it stays up, I am able to ping the other end. Have no idea what is causing this problem. All the framing, etc parameters have been set correctly according to the telco's specs.
Thanks in advance
5300>
00:03:17: %CONTROLLER-5-UPDOWN: Controller T1 0, changed state to up
5300>
00:03:19: %LINK-3-UPDOWN: Interface Serial0:0, changed state to up
00:03:20: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0:0, changed sta
te to up
5300>
00:03:37: %CONTROLLER-5-UPDOWN: Controller T1 0, changed state to down
5300>
00:03:39: %LINK-3-UPDOWN: Interface Serial0:0, changed state to down
00:03:40: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0:0, changed sta
te to down
Bronze
Re: Line going up and down
Try this
RAS1#sh contr t1
T1 0 is up.
Applique type is Channelized T1
Cablelength is long gain36 0db
No alarms detected.
alarm-trigger is not set
Version info of slot 0: HW: 1, PLD Rev: 11
Framer Version: 0x8
Manufacture Cookie Info:
EEPROM Type 0x0001, EEPROM Version 0x01, Board ID 0x4A,
Board Hardware Version 3.1, Item Number 800-3881-02,
Board Revision B0, Serial Number 21245617,
PLD/ISP Version 0.1, Manufacture Date 5-Jul-2000.
Framing is ESF, Line Code is B8ZS, Clock Source is Line Primary.
Data in current interval (745 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Total Data (last 24 hours)
0 Line Code Violations, 4 Path Code Violations,
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 4 Degraded Mins,
4 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
and see what kind of errors you are getting.
T1 0 is up.
No alarms detected.
Version info of slot 0: HW: 1, Firmware: 16, PLD Rev: 11
Framer Version: 0x8
Board Hardware Version 3.1, Item Number xxxxxxx,
Board Revision B0, Serial Number xxxxxxxx,
PLD/ISP Version 0.1, Manufacture Date xxxxxx.
Data in current interval (853 seconds elapsed):
Data in Interval 1:
Data in Interval 2:
Data in Interval 3:
Data in Interval 4:
Data in Interval 5:
however, right after the T1 goes up, it immediately goes down along with the serial interfaces and there are about 5000 path code and line code violations. I cannot specify the cable length to long either, these are the only choices available:
5300(config-controller)#cablelength ?
short short cable
so then I used short and this was the response:
5300(config-controller)#cablelength short 133ft
% Configuration of Short Cable not permitted in CSU mode
is there a way to get out of the CSU mode? I have a good feeling that the cablelength has to be set to long with the gain set as in your sh cntrl response in order to rectify this. Cheers!
291
