Line Not Comming UP after Idle-timeout ??
Hi, All,
I have a typical problem here,A router has been configured to dial out to the ISP and the users on the LAN can browse the internet.
During the day time when the router attains Idle Time out,the line is dropped, and later on when it senses any interesting traffic the line comes up.
But the problem is during the Night,When the router goes into Idle time out in the night , and stays off the whole night, Next day morning, The line does not come up even if IE is double clicked R does not in fact respond to any interesting traffic , UNLESS the router is shut down and restarted again....
Any clues why so ?? I have included the configuration below for your refrence .... ANy input for this will be highly apprecitated....
ReachMass#sh conf
Using 1362 out of 8076 bytes
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname beachmail
enable password 7 082C4D5D1A
ip subnet-zero
no ip domain-lookup
isdn switch-type basic-net3
interface Ethernet0
description connected to EthernetLAN
ip address 192.168.0.1 255.255.255.0
ip nat inside
interface BRI0
description connected to Internet
no ip address
ip nat outside
encapsulation ppp
dialer rotary-group 1
no cdp enable
interface Dialer1
ip address negotiated
ip nat outside
encapsulation ppp
no ip split-horizon
dialer in-band
dialer idle-timeout 600
dialer string 4002222
dialer hold-queue 10
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname beachmail
ppp chap password 7 02575D025B0B0E325F
ppp pap sent-username beachmail password 7 12485C4E42060D1739
ip nat inside source list 1 interface Dialer1 overload
no ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
access-list 1 permit any
access-list 1 permit 192.168.0.0 0.0.0.255
dialer-list 1 protocol ip permit
snmp-server community public RO
snmp-server chassis-id JAD053508YF
line con 0
exec-timeout 0 0
password 7 131712130804
login
stopbits 1
line vty 0 4
password 7 0833494F0A11
login
end
Thanx in advance !!!
Tauseef
tauseef@cadgulf.com
VIP Purple
Re: Line Not Comming UP after Idle-timeout ??
This looks like it should work to me. Try a command like:
debug dialer events
And make sure the router is seeing some interesting traffic. Then you could try something like:
debug isdn events (use ? to get actual syntax).
Basically, use the debug commands until you track the problem down.
First your Dialer Timeout is set to 660 Seconds. When no traffic is found your Dialer will timeout and drop.
Add this to your config.
conf t
int d1
dialer idle-timeout 2147483
dialer load-threshold 1 either
Also, add this command.
conf t
service tcp-keepalives-in
service tcp-keepalives-out
This will fix your problem.
By the way, Dont ever post your passwords in your config. These are easliy hacked.
Happy surfing!
116
