Linksys switch connecting with 2610 Eternet interface
Problems getting 2610 eternet interface and Linksys switch ports to run at same speed and duplex. When i set both device to run at same speed and duplex or use auto, When i check their running different. When i connect a cat2900xl switch with 2610, it works ok. How can i correct the problem with the Linksys switch and 2610?
1 REPLY
Silver
Re: Linksys switch connecting with 2610 Eternet interface
Linksys switches are auto speed switchs , 2610 is a 10Mbps router. So its a negotiation problem .you can use this support page if the problem is really with linksys.
http://www.linksys.com/support/default.asp
165
