Listing of IP addresses over serial
Is there any means to list out the list of ip addresses that transverse across WAN serial ? Thanks/Francis
  • Other Network Infrastructure Subjects
Re: Listing of IP addresses over serial
Francis,
I am not quit sure what do you mean by list the IP addresses which traverse
a serial link. I believe you mean to set up an IP accounting.
This can be done by configure "ip accounting" in the interface configuration
mode. Because only outgoing packets are listed after in the "show ip accounting" command, the ip accounting must be configured on both sides
of the serial link.
regards Ulrich Marzoli
www.netaid.de
Tks for yr revert. I have explored 'ip accounting' but does not meet my needs. What I require is that what are the permitted ip addresses used over the serial lines. The reason I want to know this is to prioritise the 'frequent' ip addresses on top of the extended ACL. Any tips ? Thanks/Francis
I believe, what you need is a protocol analyser to identify which IP addresses
uses which upper layer protocol and then decide, which are the mission
critical applications or you just ask the system administrators, which application they use over the serial link from which IP addresses.
That you didn't get out of the router.
www.netaid.de
Hello Francis, to sniff what packets are going over the serial lines, you might want to use an agilent advisor hardware sniffer which can be plugged in between the router and serial link.
Since all applications are running from your lan, you can just put a sniffer on the lan (software sniffer) and find out which applications are more frequently used. You can download a demo version of Agilent software sniffer at www.agilent.com
Thanks, everyone since this is the only approach available.
Rgds/Francis
97
