Community Member
LLQ and compression: HELP ME!!!!
Hi.
I have to configure LLQ and compression on frame-relay subinterfaces and PPP on a Cisco 7500. Is it possible?
I´ve heard that "fancy queueing" and compression cannot be used together and I don´t know whether this could mean that LLQ and compression are not compatible.
Enrique
1 REPLY
Re: LLQ and compression: HELP ME!!!!
Hi Enrique -
This link may prove helpful:
http://www.cisco.com/warp/public/105/compression-qos.html
This discusses some of what (I think) you're trying to do.
Clay
74
