Community Member
LLQ, EIGRP, Frame to ATM Interworking
What parameter does eigrp use for bandwidth control on a ATM internetworking interface, vbr-nrt or bandwidth?
I have a priority class that is being overdriven when EIGRP converges. It is given 50% of vbr-nrt port value. The PVC is a 64K port with a 32K CIR. My 64K port with an 8K PVC is given 90% in the priority class and is not dropping packets.
It appears that the 32K CIR has more bandwidth than the 8K in dealing with EIGRP but I cannot justify the numbers.
1 REPLY
Community Member
Re: LLQ, EIGRP, Frame to ATM Interworking
It is 50% of the bandwidth statement. This can be changed with ip bandwidth-percent eigrp command. Refer
http://www.cisco.com/univercd/cc/td/doc/product/software/ios123/123cgcr/iprrp_r/ip2_i1g.htm#1036941
Ian
97
