02-24-2003 12:01 PM - edited 03-02-2019 05:20 AM
I'm working on configuring low latency queuing on our 7206vxr router. I'd like to give preference to delay sensitive traffic. I've done so on our T1's
class-map match-any latency_sensitive_traffic
match protocol telnet
match protocol ssh
match protocol vpn
match protocol ipsec
policy-map latency
class latency_sensitive_traffic
priority 384 51200
interface Serial2/4:0
bandwidth 1544
ip address 1.2.3.4 255.255.255.0
ip load-sharing per-packet
encapsulation ppp
service-policy output latency
However I can not apply this same service-policy to the atm interface. I realize atm is a different beast, hense my problems, but don't know where to begin. The reading I have done says that QoS policies can be applied at different places, interface, sub-interface or pvc. I've tried the interface and sub-interface, reconfiguring the policy map differently. Right now my atm neophite status is limiting my understanding and options.
Does anyone have good links/example reguarding QoS and atm?
02-24-2003 12:09 PM
Try this:
http://www.cisco.com/warp/customer/121/where_policy.html
Just keep in mind that ATM Qos (out in your ATM cloud) is a completely different thing. IP to ATM Qos can be done with VC bundling and other techniques.
Hope this is what you were looking for,
Don
02-24-2003 12:18 PM
I see no reason why u cannot apply the service-policy on the atm interface or subinterface. You should be applying it on the pvc mode.
int atm 0.1 point-to-point
pvc X/YY
service-policy <>
Hope this helps...
02-24-2003 01:27 PM
Yes - reading up I attempted to apply "service-policy output latency" to in atm interface, sub-interface, and the pvc 5/500.
Again here's the what I'm tring to apply..
class-map match-any letency_sensitive_traffic
match protocol ssh
match protocol gre
match protocol pptp
match protocol l2tp
match protocol icmp
policy-map latency
class letency_sensitive_traffic
priority 384 51200
interface ATM3/0
no ip address
no ip mroute-cache
atm framing cbitplcp
no atm ilmi-keepalive
interface ATM3/0.500 point-to-point
ip address 1.2.3.4 255.255.255.252
no ip mroute-cache
pvc 5/500
oam-pvc manage
encapsulation aal5snap
service-policy input limit_file_sharing
Thanks for the advice and the previously mentioned url should help out.
02-24-2003 09:48 PM
in the original cfg, you have service-policy output latency under ATM interface and in latest post you have 'service-policy input limit_file_sharing ' . This policy doesn't exist in the cfg posted above FYI.
When you apply the service-policy to the interface, or PVC and there is a problem IOS will output a warning about insufficent bandwidth, etc. Are you seeing any errors? If you are telented into the router do a 'term mon' before applying the command. Also I see there is no vbr-rt/vbr-nrt/cbr/etc command applied to atm PVC to define the bandwidth over this PVC. This is needed when doing LLQ so LLQ uses the correct amount of bandwidth. I've had issues with service-policys not being applied when the vbr-rt/vbr-nrt, etc settings were not configured.
