load balance question
one router have two GE lines connect to the other router.
router protocal use OSPF.
and one line use MPLS LDP,but the other doesn't use MPLS.
I find the traffic mostly use the line which use MPLS LDP.
Does it normal????
Gold
Re: load balance question
If both of the paths are equal cost, and both are installed in the routing table, then the presence or lack of MPLS LDP shouldn't make any difference except for traffic which is MPLS switched. Maybe the router is load sharing all the normal traffic, but switching all of the MPLS labelled traffic along one link, causing the inbalance?
Russ
Is that to say If the router is on the MPLS cloud edge ,two interface connect to cunsumer,but one interface use mpls,the other doesn't, then the traffic will go through only one link which use mpls ???
91
