Webcast-Catalyst9k
Load Balancing 2 - 1Mbs SDSL
Is it possible to load balance 2 - 1Mbs SDSLs in a single router?
Envision an low end DSL router with NAT & DHCP on the internal LAN with the router balancing packets between two SDSL circuits to a local ISP.
Which router would be recommended?
Are there white papers/docs/examples available?
Thanks!
1 REPLY
Re: Load Balancing 2 - 1Mbs SDSL
I found a similair discussion going on in the past, may be this might give you some idea.
Refer this URL http://forums.cisco.com/eforum/servlet/NetProf?page=netprof&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.ee806e3/2#selected_message
80
